Forum: ARM programming with GCC/GNU tools Linking Problem (FPA instructions)
Author: tsp (Guest)
If I add next lines of code to lpc2106_hello_rs232_newlib example
project (beginning of main):
    int ta = 123;
    int tb = 234;
    int tc = ta / tb;
    tc = tc;
I can build the code ok, but if I change the makefile in a way that
instead of using MCU target "arm7tdmi" I use "arm926ej-s" I receive a
lot of errors:
Linking: rs232_stdio.elf
arm-elf-gcc  -mcpu=arm926ej-s   -I. -gdwarf-2 -DROM_RUN  -Os -Wall
-Wstrict-prot
otypes -Wcast-align -Wcast-qual -Wimplicit -Wmissing-prototypes
-Wnested-externs
 -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow
-Wstrict-prot
otypes -Wunused -Wa,-adhlns=build/crt0.o  -std=gnu99 -MD -MP -MF
.dep/rs232_stdi
o.elf.d build/crt0.o   rs232_stdio.o --output rs232_stdio.elf
-nostartfiles -Wl,
-Map=rs232_stdio.map,--cref -lc  -lm -lc -lgcc -Tbuild/LPC2106-ROM.ld
d:/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/bin/ld.exe:
ERROR: d:
/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a(file
no.o)
us
es FPA instructions, whereas rs232_stdio.elf does not
failed to
 merge target specific data of file
/../../arm-elf/lib\libc.a(fileno.o)
ERROR: d:
/winarm/bin/../lib/gcc/arm-elf/4.1.1/../../../../arm-elf/lib\libc.a(find
fp.o)
us
failed to
/../../arm-elf/lib\libc.a(findfp.o)
ERROR: d:
/winarm/bin/../lib/gcc/arm-elf/4.1.1\libgcc.a(_divsi3.o) uses FPA
instructions,
failed to
d:/winarm/bin/../lib/gcc/arm-elf/4.1.1\libgc
c.a(_divsi3.o)
Any idea how can I build the code shown above into "arm926ej-s" MCU? MCU
target "arm9" works also but "arm9e" causes same FPA errors.
The environment I'm using is "WinARM Version 20060606"
I am thinking about this, but until I come up with something, an lpc2106
is not an ARM9. What exactly are you targeting out of curiosity?
Author: tsp (Guest)
Yes, I faced this problem in my own kernel development project, targeted
(at the moment) for arm926ej-s because QEMU supports that :-)
The reason for using lpc2106_hello_rs232_newlib was to give other WinARM
users a possibility to try that piece of code with "arm926ej-s" target,
because this problem exists also with that makefile.
