Forum: ARM programming with GCC/GNU tools Insight lasts 10 min to start running!!
Author: fjrg76 (Guest)
From one day to another Insight lasts at least 10 min to start running
after clicking on ints name (eg windows explorer). I thought it was the
installation, althoug I've working with it for more than a month. So I
installed WinARM-20070505_sfw (I was using WinARM-20060606 release), and
happened the same, Insight lasts few minutes to start. Again I tried
with Insight that is included in Yagarto, and it lasts few minutes. I
haven't found the binaries for the latest Insigth release. Can anyone
help with this?? Thanks in advanced =)
You may try Insight from the GNUARM collection (www.gnuarm.com) which
depends on the cygwin DLLs. As far as I know cygwin is a "supported
platfrom" for Insight (MinGW/"native" Win32 isn't supported so far,
again: AFAIK, not sure). So if the issue still occurs with the version
from GNUARM you might create a bug report at
http://sourceware.org/insight/bugs.php
Hi
I tried what you told me and the results were still the same. I guess
I've used all the tool chains or win32:
winARM (the two latest releases)
Yagarto
gnuarm
keil and crossworks (just to mention, they don't use insight)
Insight works fine in other machine, so I'll format this one =(
Thanks!! =)
I needed to format my PC. I guess the badbehavior was because of
conflicts between several Insight releases and dependencies(from the all
the arm tool chain  I had installed) .From now and on I'll use only
winARM (anyway I like it a lot =))
