Forum: ARM programming with GCC/GNU tools Variable Space in internal AT91SAM7 flash
von Nick Moszer (Guest)
Hello,
Has anyone found a need to modify the linker scripts for the AT91SAM7 to
carve off some internal flash variable space?
I'm working with a AT91SAM7S256 and would LIKE to shave off the top 1k
to store variables but am having trouble getting it to work right.
Details:  using WinARM w/ gcc 4.1.1
I have the linker scripts from Martin Thomas' gamma example (last
updated on 2-Sept-06.  In my AT91SAM7S256_memory.ldh file I modified it
as follows:
MEMORY
  CODE (rx)  : ORIGIN = 0x00100000, LENGTH = 256k
  DATA (rwx) : ORIGIN = 0x00200000, LENGTH = 64k
To:
MEMORY
  CODE (rx)  : ORIGIN = 0x00100000, LENGTH = 255k
  VARS (rx)  : ORIGIN = 0x0013FC00, LENGTH = 1k
And declared a variable as:
const unsigned int checker _attribute_ ((section ("VARS"))) = 0xF;
When the linker runs and it reports the following:
Size after:
main.tmp.elf  :
section     size      addr
.text      53444   1048576
VARS           4   1102020
.data       2928   2097152
.noinit       12   2100080
.bss        3328   2100092
.comment    1512         0
Total      61228
So it looks like the variable is in the "VARS" section but the address
doesn't make sense.  It is in the "CODE" section a.k.a. addr:
0x0010D0C4.
I'm guessing I have to modify the AT91SAM7S_sections_ROM.ldh file to
accomodate this change but that file just looks scary.
Has anyone done something similar and got it to work out?
Thanks in advance for any help!
Nick Moszer wrote:
> Hello,
> as follows:
> From:
> MEMORY
> To:
> MEMORY
> Size after:
> main.tmp.elf  :
> section     size      addr
> .text      53444   1048576
> VARS           4   1102020
> .data       2928   2097152
> .noinit       12   2100080
> .bss        3328   2100092
> .comment    1512         0
> Total      61228
> 0x0010D0C4.
Wow, ok I think I actually got it.  Maybe anyway.
I just edited that AT91SAM7S_sections_ROM.ldh as (added .vars):
  .dtors :
    PROVIDE(_dtors_start_ = .);
    KEEP(*(SORT(.dtors.*)))
    KEEP(*(.dtors))
    PROVIDE(_dtors_end_ = .);
  } >CODE
  . = ALIGN(4);
  .vars :
    __vars_start = . ;
    _vars_start_ = . ;
    *(.vars)
    *(.vars.*)
    *(.gnu.linkonce.v.*)
    *(VARS)
    . = ALIGN(4);
  } >VARS
  . = ALIGN(4);
  _etext = . ;
  PROVIDE (etext = .);
  /* .data section which is used for initialized data */
  .data : AT (_etext)
Is this the proper way to do this?
