Forum: ARM programming with GCC/GNU tools linking error in winarm but not Cygwin
Author: Wayne Rice (Guest)
I have created a project for the STR9 and olimex development board
(STR-E912). I created a make file and test in cygwin and the project
compiles and links properly. when I use the same project in WINARM and
use the same make file I get errors at linking the files. Here is the
output from eclipse:
make -k all
".assembling"
arm-elf-as -m armv4t -gdwarf2 -o crt.o crt.s > crt.lst
".compiling"
arm-elf-gcc -mcpu=arm9tdmi -c -gdwarf-2 -MD -Wall -O0 -mapcs-frame
main.c 91x_lib.h 91x_map.h 91x_conf.h 91x_type.h 91x_gpio.h 91x_scu.h
91x_uart.h -o main.o
91x_it.c 91x_it.h 91x_lib.h 91x_map.h 91x_conf.h 91x_type.h 91x_gpio.h
91x_scu.h 91x_uart.h -o 91x_it.o
91x_lib.c 91x_map.h 91x_conf.h 91x_type.h -o 91x_lib.o
91x_gpio.c 91x_gpio.h 91x_map.h 91x_conf.h 91x_type.h 91x_scu.h -o
91x_gpio.o
91x_uart.c 91x_uart.h 91x_map.h 91x_conf.h 91x_type.h 91x_scu.h -o
91x_uart.o
91x_scu.c 91x_scu.h 91x_map.h 91x_conf.h 91x_type.h -o 91x_scu.o
"..linking"
arm-elf-gcc -T91x.ld --cref -t -static -lc -lgcc
-Wl,-Map=olidemo_uart.map -lm -nostartfiles -o olidemo_uart.out crt.o
main.o 91x_it.o 91x_lib.o 91x_gpio.o 91x_uart.o 91x_scu.o
main.o: file not recognized: File format not recognized
/cygdrive/c/gccfd/gnuarm/bin/../lib/gcc/arm-elf/4.0.2/../../../../arm-el
f/bin/ld:
mode armelf
crt.o
"...copying"
arm-elf-objcopy -O binary olidemo_uart.out olidemo_uart.bin
arm-elf-objcopy: 'olidemo_uart.out': No such file
arm-elf-objdump -x --syms olidemo_uart.out > olidemo_uart.dmp
arm-elf-objdump: 'olidemo_uart.out': No such file
make:  Error code 129, while making 'olidemo_uart.out' (Ignored)
make:  Error code 129, while making 'olidemo_uart_flash' (Ignored)
I am not sure why the output files are not being recognized? Any help or
advise would be greatly appreciated...
f/bin/ld:
Looks here like it is using the Cygwin linker rather than the WinARM
linker. Check your PATH environment variable.
Clifford
