Forum: ARM programming with GCC/GNU tools Make file with Flash support for OpenOcd Fails
Author: Flying Arm (flying)
Hi
My board is http://www.olimex.com/dev/index.html (Olimex - SAM7-EX256)
I need some help in flashing programming part in make file .
In make file with c++ programs support from winArm projects page i made
some changes in flashing part for example like this:
ifeq ($(FLASH_TOOL),OPENOCD)
# Program the device with Dominic Rath's OPENOCD in "batch-mode", needs
cfg and "reset-script".
program:
$(TARGET).$(IMGEXT)
@echo
@echo "Programming with OPENOCD"
C:\Program Files\openocd-2006re115\bin\openocd-ftd2xx.exe -f
at91sam7x256-armusbocd-flash-program.cfg
endif
Then when i say build make target it gives the following error
make -k program
The system cannot find the path specified.
ECHO is off.
Info:    openocd.c:82 main(): Open On-Chip Debugger (2006-10-12 18:00
CEST)
Error:   configuration.c:122 parse_config_file(): couldn't open config
file
make: *** [program] Error 1
I dont know how to add reset script overthere i tried but no use it
gives the same error.
I tried to change it with other flash programming part which i use in
the make file for C programs:
#                            FLASH PROGRAMMING      (using OpenOCD and
Amontec JTAGKey)
# Alternate make target for flash programming only
# You must create a special Eclipse make target (program) to run this
part of the makefile
# (Project -> Create Make Target...  then set the Target Name and Make
Target to "program")
# OpenOCD is run in "batch" mode with a special configuration file and a
script file containing
# the flash commands. When flash programming completes, OpenOCD
terminates.
# Note that the make file below creates the script file of flash
commands "on the fly"
# Programmers:  James P Lynch
# specify output filename here (must be *.bin file)
#TARGET = main.bin
# specify the directory where openocd executable resides
(openocd-ftd2xx.exe or openocd-pp.exe)
OPENOCD_DIR = 'C:\Program Files\openocd-2006re115\bin\'
# specify OpenOCD executable (pp is for the wiggler, ftd2xx is for the
USB debugger)
#OPENOCD = $(OPENOCD_DIR)openocd-pp.exe
OPENOCD = $(OPENOCD_DIR)openocd-ftd2xx.exe
# specify OpenOCD configuration file (pick the one for your device)
OPENOCD_CFG = $(OPENOCD_DIR)at91sam7x256-armusbocd-flash-program.cfg
# specify the name and folder of the flash programming script file
OPENOCD_SCRIPT = c:\temp\temp.ocd
# program the AT91SAM7S256 internal flash memory
program: $(TARGET).$(IMGEXT)
 @echo "Preparing OpenOCD script..."
 @cmd /c 'echo wait_halt > $(OPENOCD_SCRIPT)'
 @cmd /c 'echo armv4_5 core_state arm >> $(OPENOCD_SCRIPT)'
 @cmd /c 'echo flash write 0 $(TARGET) 0x0 >> $(OPENOCD_SCRIPT)'
 @cmd /c 'echo mww 0xfffffd08 0xa5000401 >> $(OPENOCD_SCRIPT)'
 @cmd /c 'echo reset >> $(OPENOCD_SCRIPT)'
 @cmd /c 'echo shutdown >> $(OPENOCD_SCRIPT)'
 @echo "Flash Programming with OpenOCD..."
 $(OPENOCD)  -f $(OPENOCD_CFG)
 @echo "Flash Programming Finished."
When i use this the problem here is its flashing the main.cpp program
for around 130 seconds and says flashing complete and nothing happens.
The problem with this script is its flashing the .cpp file instead of
.bin file .You can see above #TARGET = main.bin , i commented this
because in the script of makefile we already have TARGET = main command.
But here IMGEXT means bin declared i dont understand why its taking just
the main file $(TARGET).$(IMGEXT)
So there's a kind of conflict .
Here is the complete makefile:
# Hey Emacs, this is a -*- makefile -*-
# WinARM template makefile
# by Martin Thomas, Kaiserslautern, Germany
# <eversmith@heizung-thomas.de>
# based on the WinAVR makefile written by Eric B. Weddington, Jörg
Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make program = Download the hex file to the device
# (TODO: make filename.s = Just compile filename.c into the assembler
code only)
# To rebuild project do "make clean" then "make all".
# Changelog:
# - 17. Feb. 2005  - added thumb-interwork support (mth)
# - 28. Apr. 2005  - added C++ support (mth)
# - 29. Arp. 2005  - changed handling for lst-Filename (mth)
# -  1. Nov. 2005  - exception-vector placement options (mth)
# - 15. Nov. 2005  - added library-search-path (EXTRA_LIB...) (mth)
# -  2. Dec. 2005  - fixed ihex and binary file extensions (mth)
# - 22. Feb. 2006  - added AT91LIBNOWARN setting (mth)
# - 19. Apr. 2006  - option FLASH_TOOL (default lpc21isp); variable
IMGEXT (mth)
# - 23. Jun. 2006  - option USE_THUMB_MODE -> THUMB/THUMB_IW
# -  3. Aug. 2006  - added -ffunction-sections -fdata-sections to CFLAGS
#                    and --gc-sections to LDFLAGS. Only availble for gcc
4 (mth)
SHELL = cmd
#FLASH_TOOL = UVISION
FLASH_TOOL = OPENOCD
# MCU name and submodel
MCU      = arm7tdmi
SUBMDL   = AT91SAM7X256
USE_THUMB_MODE = YES
#USE_THUMB_MODE = NO
## Create ROM-Image (final)
RUN_MODE=ROM_RUN
## Create RAM-Image (debugging)
##( not used: example does not fit in AT91SAM7S64 RAM )
#RUN_MODE=RAM_RUN
## Exception-Vector placement only supported for "ROM_RUN"
## (placement settings ignored when using "RAM_RUN")
## - Exception vectors in ROM:
#VECTOR_LOCATION=VECTORS_IN_ROM
## - Exception vectors in RAM:
VECTOR_LOCATION=VECTORS_IN_RAM
# Target file name (without extension).
TARGET = main
# List C source files here. (C dependencies are automatically
generated.)
# use file-extension c for "c-only"-files
#SRC = dbgu.c
#SRC += syscalls.c
#SRC += swi_handler_user.c
SRC += lcd.c
SRC += lowlevelinit.c
# SRC += rprintf.c
# List C source files here which must be compiled in ARM-Mode.
#SRCARM  = common/Cstartup_SAM7.c
# List C++ source files here.
# use file-extension cpp for C++-files (use extension .cpp)
CPPSRC = $(TARGET).cpp
# List C++ source files here which must be compiled in ARM-Mode.
CPPSRCARM =
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# List Assembler source files here which must be assembled in ARM-Mode..
#ASRCARM  = common/Cstartup.S
#ASRCARM += common/swi_handler.S
ASRCARM  = crt.S
## Output format. (can be ihex or binary)
## (binary i.e. for openocd and SAM-BA, hex i.e. for lpc21isp and
uVision)
#FORMAT = ihex
FORMAT = binary
# Optimization level, can be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
#OPT = 0
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
#DEBUG = stabs
DEBUG = dwarf-2
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
EXTRAINCDIRS = ./common
# List any extra directories to look for library files here.
#EXTRA_LIBDIRS = ../arm7_efsl_0_2_4
EXTRA_LIBDIRS =
## Using the Atmel AT91_lib produces warning with
## the default warning-levels.
## yes - disable these warnings; no - keep default settings
AT91LIBNOWARN = yes
#AT91LIBNOWARN = no
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options for C here
CDEFS =  -D$(RUN_MODE)
# Place -I options here
CINCS =
# Place -D or -U options for ASM here
ADEFS =  -D$(RUN_MODE)
ifdef VECTOR_LOCATION
CDEFS += -D$(VECTOR_LOCATION)
ADEFS += -D$(VECTOR_LOCATION)
endif
CDEFS += -D__WinARM__
ADEFS += -D__WinARM__
# Compiler flags.
ifeq ($(USE_THUMB_MODE),YES)
THUMB    = -mthumb
THUMB_IW = -mthumb-interwork
else
THUMB    =
THUMB_IW =
endif
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
# Flags for C and C++ (arm-elf-gcc/arm-elf-g++)
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -ffunction-sections -fdata-sections
CFLAGS += -Wall -Wcast-align -Wimplicit
CFLAGS += -Wpointer-arith -Wswitch
CFLAGS += -Wredundant-decls -Wreturn-type -Wshadow -Wunused
CFLAGS += -Wa,-adhlns=$(subst $(suffix $<),.lst,$<)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
# flags only for C
CONLYFLAGS += -Wnested-externs
CONLYFLAGS += $(CSTANDARD)
ifneq ($(AT91LIBNOWARN),yes)
#AT91-lib warnings with:
CFLAGS += -Wcast-qual
CONLYFLAGS += -Wmissing-prototypes
CONLYFLAGS += -Wstrict-prototypes
CONLYFLAGS += -Wmissing-declarations
endif
# flags only for C++ (arm-elf-g++)
CPPFLAGS = -fno-rtti -fno-exceptions
# Assembler flags.
#  -ahlns:     create listing
#  -g$(DEBUG): have the assembler create line number information
ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:.S=.lst),--g$(DEBUG)
#Additional libraries.
# Extra libraries
#    Each library-name must be seperated by a space.
#    To add libxyz.a, libabc.a and libefsl.a:
#    EXTRA_LIBS = xyz abc efsl
#EXTRA_LIBS = efsl
EXTRA_LIBS =
#Support for newlibc-lpc (file: libnewlibc-lpc.a)
#NEWLIBLPC = -lnewlib-lpc
MATH_LIB = -lm
CPLUSPLUS_LIB = -lstdc++
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -nostartfiles -Wl,-Map=$(TARGET).map,--cref,--gc-sections
LDFLAGS += -lc
LDFLAGS += $(NEWLIBLPC) $(MATH_LIB)
LDFLAGS += -lc -lgcc
LDFLAGS += $(CPLUSPLUS_LIB)
LDFLAGS += $(patsubst %,-L%,$(EXTRA_LIBDIRS))
LDFLAGS += $(patsubst %,-l%,$(EXTRA_LIBS))
# Set Linker-Script Depending On Selected Memory and Controller
ifeq ($(RUN_MODE),RAM_RUN)
LDFLAGS +=-T./common/$(SUBMDL)-RAM.ld
else
LDFLAGS +=-T./common/$(SUBMDL)-ROM.ld
endif
# Flash-Programming support using lpc21isp by Martin Maurer
# only for Philips LPC and Analog ADuC ARMs
# Settings and variables:
#LPC21ISP = lpc21isp
#LPC21ISP_PORT = com1
#LPC21ISP_BAUD = 38400
#LPC21ISP_XTAL = 12000
#LPC21ISP_FLASHFILE = $(TARGET).hex
# verbose output:
#LPC21ISP_DEBUG = -debug
# enter bootloader via RS232 DTR/RTS (only if hardware supports this
# feature - see Philips AppNote):
#LPC21ISP_CONTROL = -control
# Define directories, if needed.
## DIRARM = c:/WinARM/
## DIRARMBIN = $(DIRAVR)/bin/
## DIRAVRUTILS = $(DIRAVR)/utils/bin/
# Define programs and commands.
CC = arm-elf-gcc
CPP = arm-elf-g++
OBJCOPY = arm-elf-objcopy
OBJDUMP = arm-elf-objdump
SIZE = arm-elf-size
NM = arm-elf-nm
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = "-------- begin (mode: $(RUN_MODE)) --------"
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_FLASH = Creating load file for Flash:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_ARM = "Compiling C (ARM-only):"
MSG_COMPILINGCPP = Compiling C++:
MSG_COMPILINGCPP_ARM = "Compiling C++ (ARM-only):"
MSG_ASSEMBLING = Assembling:
MSG_ASSEMBLING_ARM = "Assembling (ARM-only):"
MSG_CLEANING = Cleaning project:
MSG_FORMATERROR = Can not handle output-format
MSG_LPC21_RESETREMINDER = You may have to bring the target in
bootloader-mode now.
# Define all object files.
COBJ      = $(SRC:.c=.o)
AOBJ      = $(ASRC:.S=.o)
COBJARM   = $(SRCARM:.c=.o)
AOBJARM   = $(ASRCARM:.S=.o)
CPPOBJ    = $(CPPSRC:.cpp=.o)
CPPOBJARM = $(CPPSRCARM:.cpp=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(ASRCARM:.S=.lst) $(SRC:.c=.lst)
$(SRCARM:.c=.lst)
LST += $(CPPSRC:.cpp=.lst) $(CPPSRCARM:.cpp=.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -MD -MP -MF dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS  = -mcpu=$(MCU) $(THUMB_IW) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. -x assembler-with-cpp
$(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
ifeq ($(FORMAT),ihex)
build: elf hex lss sym
hex: $(TARGET).hex
IMGEXT=hex
else
ifeq ($(FORMAT),binary)
build: elf bin lss sym
bin: $(TARGET).bin
IMGEXT=bin
else
$(error "$(MSG_FORMATERROR) $(FORMAT)")
endif
endif
elf: $(TARGET).elf
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye candy.
begin:
  @echo
  @echo $(MSG_BEGIN)
finished:
  @echo $(MSG_ERRORS_NONE)
end:
  @echo $(MSG_END)
  @echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
sizebefore:
#  @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE);
$(ELFSIZE); echo; fi
sizeafter:
#  @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER);
# Display compiler version information.
gccversion :
  @$(CC) --version
  @echo
endif
# Create final output file (.hex) from ELF output file.
%.hex: %.elf
  @echo
  @echo $(MSG_FLASH) $@
  $(OBJCOPY) -O $(FORMAT) $< $@
# Create final output file (.bin) from ELF output file.
%.bin: %.elf
  @echo
# Create extended listing file from ELF output file.
# testing: option -C
%.lss: %.elf
  @echo
  @echo $(MSG_EXTENDED_LISTING) $@
  $(OBJDUMP) -h -S -C $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
  @echo
  @echo $(MSG_SYMBOL_TABLE) $@
  $(NM) -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
%.elf:  $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
  @echo
  @echo $(MSG_LINKING) $@
  $(CC) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ)
$(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS)
#  $(CPP) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ)
# Compile: create object files from C source files. ARM/Thumb
$(COBJ) : %.o : %.c
  @echo
  @echo $(MSG_COMPILING) $<
  $(CC) -c $(THUMB) $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C source files. ARM-only
$(COBJARM) : %.o : %.c
  @echo
  @echo $(MSG_COMPILING_ARM) $<
  $(CC) -c $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM/Thumb
$(CPPOBJ) : %.o : %.cpp
  @echo
  @echo $(MSG_COMPILINGCPP) $<
  $(CPP) -c $(THUMB) $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM-only
$(CPPOBJARM) : %.o : %.cpp
  @echo
  @echo $(MSG_COMPILINGCPP_ARM) $<
  $(CPP) -c $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files. ARM/Thumb
## does not work - TODO - hints welcome
##$(COBJ) : %.s : %.c
##  $(CC) $(THUMB) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM/Thumb
$(AOBJ) : %.o : %.S
  @echo
  @echo $(MSG_ASSEMBLING) $<
  $(CC) -c $(THUMB) $(ALL_ASFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM-only
$(AOBJARM) : %.o : %.S
  @echo
  @echo $(MSG_ASSEMBLING_ARM) $<
  $(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
  @echo
  @echo $(MSG_CLEANING)
  $(REMOVE) ../Common_WinARM/$(TARGET).hex
  $(REMOVE) $(TARGET).hex
  $(REMOVE) $(TARGET).bin
  $(REMOVE) $(TARGET).obj
  $(REMOVE) $(TARGET).elf
  $(REMOVE) $(TARGET).map
  $(REMOVE) $(TARGET).a90
  $(REMOVE) $(TARGET).sym
  $(REMOVE) $(TARGET).lnk
  $(REMOVE) $(TARGET).lss
  $(REMOVE) $(COBJ)
  $(REMOVE) $(CPPOBJ)
  $(REMOVE) $(AOBJ)
  $(REMOVE) $(COBJARM)
  $(REMOVE) $(CPPOBJARM)
  $(REMOVE) $(AOBJARM)
  $(REMOVE) $(LST)
  $(REMOVE) $(SRC:.c=.s)
  $(REMOVE) $(SRC:.c=.d)
  $(REMOVE) $(SRCARM:.c=.s)
  $(REMOVE) $(SRCARM:.c=.d)
  $(REMOVE) $(CPPSRC:.cpp=.s)
  $(REMOVE) $(CPPSRC:.cpp=.d)
  $(REMOVE) $(CPPSRCARM:.cpp=.s)
  $(REMOVE) $(CPPSRCARM:.cpp=.d)
  $(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex bin lss sym clean clean_list program
Regards
Rajitha
Author: Jonathan Dumaresq (dumarjo)
> program:
> $(TARGET).$(IMGEXT)
> @echo
where this at91sam7x256-armusbocd-flash-program.cfg file is located ?
Jonathan
>> program:
>> $(TARGET).$(IMGEXT)
>> @echo
> In the same location C:\Program Files\openocd-2006re115\bin
Regards
Rajitha
>>> program:
>>> $(TARGET).$(IMGEXT)
>>> @echo
> Regards
> Rajitha
Hi
I changed the above line something like this
'C:\Program Files\openocd-2006re115\bin\'openocd-ftd2xx.exe -f
'C:\Program
Files\openocd-2006re115\bin\'at91sam7x256-armusbocd-flash-program.cfg
Now flashing seems to work. There was just missing ' '.
But nothing happens with my main file. I think i need to rework on c++
programs . The same file in c works fine when i flash my board but i
tried to flash the same program converted into c++ now it doesn't work.
Anyone programming in c++ with ARM SAM7X256 Olimex Board ?
Please let me know. It will be of great help to me.
Regards
Rajitha
