Forum: ARM programming with GCC/GNU tools Start Up File + Linker Script + Makefile + LPC2888
von Mario (Guest)
Hello...
Are there any makefiles, linker scripts and start up files available for
the LPC2888???
I have been looking around now for quite a long time and cant find any
support.
Maybe one of you guys can help.
Thank you very much!
Mario
von Martin Thomas (Guest)
Mario wrote:
> Hello...
> the LPC2888???
> support.
> Mario
So far I have not used this model so take the following for what it's
worth:
If you can not find "ready-made" files for the GNU-toolchain search for
code-examples from the commercial tool vendors (IAR, Green Hills,
Keil/ARM etc.). If you find an example you at least get an idea how the
startup-code should look like (esp. the setup for the external memory
interface). Usualy it's rather easy to port assembler-code from one
"syntax" to another. Linker-scripts are somehow generic, basicly you can
take a linker-script for another target and adjust memory-locations and
-sizes. You may have to add additional memory-sections for external
memory and assign the c-sections accordingly. Maybe the linker-scripts
for the gba from devkitpro can serve as examples for this.
Martin Thomas
