Forum: ARM programming with GCC/GNU tools make fails
Author: Tilo (Guest)
Hi
I have switched to vista and have a little problem with winarm:
> "make" all
-------- begin (mode: ROM_RUN) --------
arm-elf-gcc (GCC) 4.1.1 (WinARM)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Assembling (ARM-only): startup.S
arm-elf-gcc: CreateProcess: No such file or directory
make: *** [startup.o] Error 1
> Process Exit Code: 2
> Time Taken: 00:00
Any idea what this error means? My first idea was missing path entries
in the system variable. I checked them and I can call winarm binaries
from every folder so this should be OK.
Author: Stefan (Guest)
Tilo wrote:
> Hi
>> "make" all
>> Time Taken: 00:00
There are issues with GCC on Vista with WinAVR too.
http://www.avrfreaks.net/index.php?name=PNphpBB2&f...
One solution i have seen was the installation of a virtual machine with
XP as development system.
Stefan
Author: Peter (Guest)
I had the same problem compiling my AT91SAM7 code with WinARM under
Vista (Home Premium).
To get it working I had to extend the environment search PATH. I use the
following  batch file:
@echo off
set
PATH=C:\WinARM\bin;c:\WinARM\arm-elf\bin;c:\WinARM\utils\bin;c:\winarm\l
ibexec\gcc\arm-elf\4.1.1;c:\cygwin\bin;%PATH%
echo Path set
Peter
Author: Vishal Arora (vishal)
Tilo wrote:
> Hi
>> "make" all
> NO
> PURPOSE.
>> Time Taken: 00:00
Hi Tilo
First, as Peter said follow these steps:
http://winarm.scienceprog.com/winarm-tools/quick-s...
Second, might be that you are running Programmers Notepad from batch
file and not from the pn.exe file given in folder 'pn'
"Sometimes we miss very simple things"
Vishal
