Forum: ARM programming with GCC/GNU tools what is memory remapping in ARM 7 and why we need this ?
Author: Robin Singh (singh_robin28)
hello friends plz give me answer
thanks in advance
Author: A.K. (Guest)
Reset starts at 0, exceptions a few words up. In production you
therefore need ROM at address 0. If you want to debug your program in
RAM, you either need RAM at address 0 or you have to map the exception
vectors to RAM.
> vectors to RAM.
thanks AK
can u give me more details or any Doc or link on this memory remaping i
will be thank ful to
robin
See docs of the controller to be used. Implemented differently.
The vector table starts at address zero. This includes the reset vector,
which is where code starts executing from on power-up, so this needs to
be non-volatile. If you need to be able to change the exception and
interupt vectors at runtime, then RAM must be mapped to address zero.
The part user manual will contain all teh details for a specific
controller. ARM9 and StrongARM parts and later have full MMU's rather
than the simple re-mappers typically implemented on ARM7.
Clifford
More info ...
For NXP(Philips)LPC2000 series see
http://www.hitex.de/pdf/whitepapers/WP-ARM-0102.pdf
For Atmel AT91x40 see
http://www.hitex.de/pdf/whitepapers/WP-ARM-0104.pdf
Clifford
Clifford Slocombe wrote:
> More info ...
> Clifford
Realy thanks NOW I AM CLEAR
ROBIN
>> More info ...
>> Clifford
> ROBIN
agin small question sir :what do u mean by"change the exception and
interupt vectors at runtime",plz give ans
thanks in advance
> thanks in advance
When an interrupt (for example) occurs, it will execute the jump
instruction placed at the interrupt vector address. In a ROM based
static system this can be set at build time to jump to a ROM based
interrupt handler. In more complex situations it may not be possible or
convenient to have a fixed interrupt vector. For example a bootloader
may use a ROM based interrupt but loads the application to RAM which may
require different interrupt handling, so the vector must be modifiable
at run-time.
Another reason for mapping the table to RAM is that RAM is typically
faster than ROM (some LPC2xxx parts have FLASH accelerators that make
this not so in some cases), so you can reduce interrupt latency this
way. You would probably also want the handlers to execute in RAM in this
case.
Clifford
> Robin Singh wrote:
>> Robin Singh wrote:
> Clifford
again thank u very much sir
robin
