Forum: ARM programming with GCC/GNU tools Regarding General BIOS writting
Author: Dharmendra Vasadia (dharmendra)
Hi ALL,
sorry to ask such question.
I am expecting project for BIOS writing. I have some queries regarding
BIOS writing.
 What tools and languages are used to write BIOS?
 Is there any documentation for understanding of BIOS?
 What must be the content of the BIOS?
Please send me reply any thing you know regarding this
Dharmendra
Author: Martin Thomas (Guest)
> BIOS writing.
By far not enough information.
See the FreeBIOS project for an example of a "real" BIOS for PC-like
hardware. For microcontrollers some functions of a bios can be
implements by code at a fixed location which offers an array of pointers
to functions which provide for example file or console I/O. For
ARM-controllers (and maybe others) this can simplified by using
SWI-calls as interface. You can see the syscalls which are needed by
newlib to interface with the hardware as "BIOS".
Martin Thomas
BIOS is simply a term used for basic I/O services on a platform. There
is no 'standard' for what a BIOS should contain, unless you are
referring to teh PC BIOS, but that is not implemented on ARM of course.
Typically you put in it what you need and to support teh hardware on
your board.
ARM supports software interrupts which allows such code to be installed
and called without being explicitly linked to the calling application -
i.e the caller does notneed to know the address of a function.
You can use C, but will may need some assembler to do some of the 'glue'
such as setting up vector tables. Similar code is already needed for yur
C run-time startup.
As I sait there is no 'one thing' called a BIOS, it is a generic term
for low-level hardware/platform support code.
Whatever you need to support the hardware on your board. Serial comms is
probably a good start, you can then use that to hook into the syscalls
code.
