Forum: ARM programming with GCC/GNU tools OpenOCD uploads only 4096 bytes (LPC214x/Wiggler)
von Led L. (ledelectronics)
Hi guys,
I'm trying to upload my code to LPC2146 uC using Wiggler-clone parallel
port interface + openocd. It works successfully when code size is below
4096 bytes. If code is longer then openocd (latest ver installed) upload
skips to transfer data above 0x1000. I did lot of tests by modifying
scripts but no solution yet. Code is compiled by latest WinARM package
(20060606).
Any suggestion where to look for a error?
openocd reports that all is fine:
c:\Apps\openocd-2006re100\bin\openocd-pp.exe -d2 -f
oocd_flash2146_wig.cfg
Info:    openocd.c:82 main(): Open On-Chip Debugger (2006-09-28 20:00
CEST)
Info:    target.c:219 target_init_handler(): executing reset script
'oocd_flash2146.script'
Thank you!
Linnar
I found a solution:
flash erase 0 0 *
where * > 0, then it erases next sectors also and is able to write!!! I
had 0 in my script and this was reason of failure.
