Hi everyone,
When I use GNU ARM to compile my code, I got a compile warning
of "cast increases required alignment of target type"
on the line of
PartInfo = *((struct partrecord *) ((struct partsector *)
SectorBuffer)->psPart);
Here partsector is structure of
struct partsector
char psPartCode[512-64-2]; //!< pad so struct is 512b
unsigned char psPart[64]; //!< four partition records (64
bytes)
unsigned char psBootSectSig0; //!< two signature bytes (2 bytes)
unsigned char psBootSectSig1;
#define BOOTSIG0 0x55
#define BOOTSIG1 0xaa
and partrecord is struct of
struct partrecord // length 16 bytes
unsigned char prIsActive; //!< 0x80 indicates active
partition
unsigned char prStartHead; //!< starting head for partition
unsigned int prStartCylSect; //!< starting cylinder and sector
unsigned char prPartType; //!< partition type (see above)
unsigned char prEndHead; //!< ending head for this partition
unsigned int prEndCylSect; //!< ending cylinder and sector
unsigned long prStartLBA; //!< first LBA sector for this
partition
unsigned long prSize; //!< size of this partition (bytes
or
sectors ?)
I am trying to get rid of this warning, but fail. nsd when I run to this
line by step running, the code run away.
Does anybody know how to fix it?
I have the same warning on other similiar lines.
Thanks
Min Ge
Hi Everyone, I got a help info from old message of A. Den Toom's reply. http://en.mikrocontroller.net/topic/64486#73570 if I define struct as: _attribute_ ((_packed_)) typedef struct _attribute_ ((_packed_)) { char psPartCode[512-64-2]; //!< pad so struct is 512b unsigned char psPart[64]; //!< four partition records (64 bytes) unsigned char psBootSectSig0; //!< two signature bytes (2 bytes) unsigned char psBootSectSig1; #define BOOTSIG0 0x55 #define BOOTSIG1 0xaa }partsector; The awrning is gone. Thanks Min Ge
Hi everyone, I got this warning again, but not on structure. Just when I convet an array (char array) address to long int pointer fat32Buffer= (unsigned long *)FatCache; FatCache is array of char FatCache [512]; I do not know how to get rid of the warning on such code. thanks. Min ge
Try: char FatCache[512] _attribute_ ((aligned)) ; Ref: http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Variable-Attributes.html#Variable-Attributes Clifford
Clifford Slocombe wrote: > Try: > > char FatCache[512] _attribute_ ((aligned)) ; > > > Ref: > http://gcc.gnu.org/onlinedocs/gcc-4.1.1/gcc/Variable-Attributes.html#Variable-Attributes > > Clifford Hi Clifford, Thanks for you help. I did have tried what you wrote with char FatCache[512] _attribute_ ((aligned (4))) ; I am pretty sure the array start with multiples of 4. I just do not want the warning infomation display anymore. I know if I get rid of "-Wcast-align" in makefile, this warning will be gone. But I do not want, I still hope the warning to display if I have such problem. Thanks. Min Ge
Min Ge wrote: > Thanks for you help. I did have tried what you wrote with > > char FatCache[512] _attribute_ ((aligned (4))) ; > > I am pretty sure the array start with multiples of 4. I just do not want > the warning infomation display anymore. You are not clear whether that solved the problem or not, or whether you tried exactly what I suggested. Without the parameter, the alignment will be set to the 'maximum useful alignment for the target machine', so you need make no assumptions. However, I don't think this is a solution: The documentation for -Wcast-align simply states it will generate a warning when such a cast is made. It does not say that the warning will only be issued when the alignment is increased. Min Ge wrote: > I know if I get rid of "-Wcast-align" in makefile, this warning will be > gone. > But I do not want, I still hope the warning to display if I have such > problem. Note that the warning is not that the cast is misalighed, merely that alignment is increased to make the cast safe - so the issuing of the warning is entirely unnecessary. It is only potentially relevant if you are down to your last few bytes of RAM, when the potential realignment may waste as much as three bytes! You will probably find however that the compiler is smart enough to align the data on word boundaries in any case since this results in potentially faster code. There are generally few reasons to switch on any warnings other than -Wall (and possibly -Wformat). If you have a genuine reason for having this warning, then you need to rewrite your code to avoid it. Casts are often indicitive of a general failure in design in anycase, and you should consider your coding practices. A simple way to avoid the issue is to ensure type agreement in the first instance so casts are unnecessary. A simple solution to your problem is to declare the array thus: FatCache is array of unsigned long FatCache [128]; fat32Buffer = FatCache; If you later need to access FatCache as a char array, casting to char* will not cause the warning because the alignment need not be increased. An possibly better alternative is to switch the declarations: unsigned long fat32Buffer[128]; FatCache = (char*)fat32Buffer ; Clifford
Clifford Slocombe wrote: > unsigned long FatCache [128]; > fat32Buffer = FatCache; > > If you later need to access FatCache as a char array, casting to char* > will not cause the warning because the alignment need not be increased. > An possibly better alternative is to switch the declarations: > > unsigned long fat32Buffer[128]; > FatCache = (char*)fat32Buffer ; > > Clifford This is a good idea. I will try it. Thanks a lot. Min Ge
Guest
#1171889
Thanks from me, too, Clifford. AllenK
Guest
#2415838
Thank you Clifford. you explained it wonderfully.
Please log in before posting.
