Forum: ARM programming with GCC/GNU tools AT91RM9200 command line compilation options using winarm,
Author: ac (Guest)
I m using Winarm tool and AT91RM9200 processor. I would like to know
that wheather the tool works with said processor? If so plz suggest the
command line options.
Author: Stefan (Guest)
There is at least a register definition file for the AT91RM9200. But
there are no examples for this µC.
So i think you have to write linker control scripts and startup code.
Perhaps you can use some code from WinARMs AT91SAM764 examples. But this
is no trival task for a beginner with this µC and/or ARM assembler/C.
Stefan
Author: Martin Thomas (Guest)
> Stefan
A good starting point are the examples provided by Atmel on
http://www.at91.com/Pages/products/EvaluationBoard...
The header-files with the register-defintions should work out of the box
with any C-compiler. An example startup-code is available from Atmel for
ADS- and the Green-Hills-toolchain but it is not very difficult to port
them to the gnu-Assembler. For a linker-script please read the
ld-documentation, it's not very difficult to setup a simple
linker-script for the first steps but it may be some work to get
everything right (remapping etc.).
Martin Thomas
