C code porting to arm
OP #1171181
Hi all,
 I have a c code to be ported to arm.Iam using the GNU tool
cahain(WinARM).When iam linking the objects created by the
arm-elf-gcc(version 4.1.0) using ld,iam getting errors like
"undefined refernce to _modsi3,_divsi3,_sbrk_o,_nedf2,_adddfr3
.Can anyone help me in solving this errors.
Mithun
Guest #1171182
Check the command-line options to the linker. It seems libc (-lc) and/or
libgcc (-lgcc) is/are missing. The "missing" sbrk is a FAQ: please read
the WinARM readme-file or search this forum.
Martin Thomas
OP #1171183
> Martin Thomas
Dear Martin,
I have included the commandline options you specified,the errors get
reduced,
but still iam getting errors given below
E:\WinARM\arm-elf\lib\libc.a(freer.o): In function
`_malloc_trim_r':mallocr.c:(.
text+0x48): undefined reference to `_sbrk_r'
:mallocr.c:(.text+0x64): undefined reference to `_sbrk_r'
:mallocr.c:(.text+0x84): undefined reference to `_sbrk_r'
E:\WinARM\arm-elf\lib\libc.a(fseek.o): In function
`_fseek_r':fseek.c:(.text+0x1
58): undefined reference to `_fstat_r'
:fseek.c:(.text+0x1b0): undefined reference to `_fstat_r'
E:\WinARM\arm-elf\lib\libc.a(makebuf.o): In function
`__smakebuf':makebuf.c:(.te
xt+0x3c): undefined reference to `_fstat_r'
E:\WinARM\arm-elf\lib\libc.a(mallocr.o): In function
`_malloc_r':mallocr.c:(.tex
t+0x424): undefined reference to `_sbrk_r'
:mallocr.c:(.text+0x4cc): undefined reference to `_sbrk_r'
E:\WinARM\arm-elf\lib\libc.a(stdio.o): In function
`__sclose':stdio.c:(.text+0xc
): undefined reference to `_close_r'
`__sseek':stdio.c:(.text+0x30
): undefined reference to `_lseek_r'
`__swrite':stdio.c:(.text+0x8
4): undefined reference to `_lseek_r'
:stdio.c:(.text+0xac): undefined reference to `_write_r'
`__sread':stdio.c:(.text+0xd0
): undefined reference to `_read_r'
E:\WinARM\arm-elf\lib\libc.a(sysclose.o): In function
`close':sysclose.c:(.text+
0xc): undefined reference to `_close_r'
E:\WinARM\arm-elf\lib\libc.a(syslseek.o): In function
`lseek':syslseek.c:(.text+
0x24): undefined reference to `_lseek_r'
E:\WinARM\arm-elf\lib\libc.a(sysopen.o): In function
`open':sysopen.c:(.text+0x2
c): undefined reference to `_open_r'
E:\WinARM\arm-elf\lib\libc.a(sysread.o): In function
`read':sysread.c:(.text+0x2
4): undefined reference to `_read_r'
E:\WinARM\arm-elf\lib\libc.a(syswrite.o): In function
`write':syswrite.c:(.text+
0x24): undefined reference to `_write_r'
E:\WinARM\arm-elf\lib\libc.a(time.o): In function
`time':time.c:(.text+0x1c): un
defined reference to `_gettimeofday_r'
E:\WinARM\arm-elf\lib\libc.a(vfprintf.o): In function
`_vfprintf_r':vfprintf.c:(
.text+0x6c4): undefined reference to `__ltdf2'
:vfprintf.c:(.text+0x810): undefined reference to `__nedf2'
:vfprintf.c:(.text+0x838): undefined reference to `__eqdf2'
:vfprintf.c:(.text+0x1354): undefined reference to `__eqdf2'
:vfprintf.c:(.text+0x1904): undefined reference to `__nedf2'
E:\WinARM\arm-elf\lib\libc.a(dtoa.o): In function
`_dtoa_r':dtoa.c:(.text+0x2c4)
:dtoa.c:(.text+0x42c): undefined reference to `__ltdf2'
:dtoa.c:(.text+0x450): undefined reference to `__nedf2'
:dtoa.c:(.text+0x490): undefined reference to `__ltdf2'
:dtoa.c:(.text+0x7e8): undefined reference to `__ltdf2'
:dtoa.c:(.text+0x8dc): undefined reference to `__gtdf2'
:dtoa.c:(.text+0x8f8): undefined reference to `__ltdf2'
:dtoa.c:(.text+0x9ac): undefined reference to `__ltdf2'
:dtoa.c:(.text+0x9dc): undefined reference to `__ltdf2'
:dtoa.c:(.text+0xad0): undefined reference to `__gtdf2'
:dtoa.c:(.text+0xb08): undefined reference to `__ltdf2'
:dtoa.c:(.text+0xbc4): undefined reference to `__gedf2'
:dtoa.c:(.text+0xc54): undefined reference to `__gtdf2'
:dtoa.c:(.text+0xc70): undefined reference to `__eqdf2'
:dtoa.c:(.text+0xcf4): undefined reference to `__nedf2'
Can you suggest me where the problem is.
Regards
Mithun
#1171184
> reduced,
All of the references suffixed _r are the stubs that link the standard
library to your target platform (the syscalls). You have to provide
these as part of your BSP. See the newlib documentation for details.
Example syscall modules for a number of reference platforms are provided
with WinARM.
All the __xxxf2 sysmbols are related to floating point handling. They
are defined in libgcc.a (-lgcc).
It would be helpful if you included that actual linker invokation in
your log rather than just the error messages. The order in which the
libraries are linked is also critical unless you group them. The linker
will not by default itereate through libraries to resolve symbols, so
when an unresolved symbol is encountered, its definition must have
previously been encountered in a previous library. Grouping allows a set
of libraries to be checked iteratively to resolve links in any order or
circular dependencies. This is slightly less efficient that just getting
the link order right in the first place, but unless the build is large
(and it seldom is on a microcontroller), you won't notice. I use the
following:
--start-group -lc -lm -lgcc -lstdc++ --end-group
You won't need -lstdc++ if you are not using C++.
Clifford
Guest #1171185
It's not very polite to post a question to serveral places at the same
time (comp.sys.arm and here and maybe somewhere else). Wait some time
(at least a day) for answers from a forum/newsgroup before asking at
another place.
#1171186
> another place.
That's an intersting take on netiquette; I've never heard that one
before and would have to strongly disagree. If someone has an issue to
resolve and a deadline to meet I'd say that it was legitimate to seek an
answer from any and all possible resources - in parallel. It is not IMO
reasonable to assume that all ARM related forums are occuied by the same
people - because they are not. I for one have never used comp.sys.arm,
so he'd have not had the benefit of my input ;-).
Clifford
Guest #1171187
>> another place.
Clifford,
I know that there are different opionions on parallel postings.
Obviously we do not share the opinion about this. Of cause everybody is
free to send questions to any forum or newsgroup he/she can find and it
might be somehow justified if there is a deadline to meet. My opinion is
not that unusual but maybe influenced too much by personal experience
and observations. I have spent a lot of time on answering in forums or
answering e-mails and found out later that the one who has asked the
question already received an answer in another forum/newsgroup. When
this happens I feel that I have wasted my (free) time for (free)
"consulting" and I know that I'm not the only one who has made this
experiences.
I hope this explains my opinion.
I'd like to take this opportunity to thank you for your valuable input
to this forum. Your participation is very welcome.
Martin Thomas
OP #1171188
>> reduced,
> with WinARM.
> Clifford
Dear clifford,
As per your suggestion while linking i included the system call
functions and  was able to reduce the errors.
But still there are errors(given below).can you suggest me where  the
problem is.
I invoked the linker using : arm-elf-ld --output=1.elf --startgroup -lc
-lm -lgcc --end-group
_write_r.o: In function `_write_r':E:\WinARM\bin/_write_r.c:103:
undefined refer
ence to `device_table'
_ioctl_r.o: In function `_ioctl_r':E:\WinARM\bin/_ioctl_r.c:75:
undefined refere
image.o: In function `init_picture':E:\WinARM\bin/image.c:1111:
undefined refere
nce to `ftime'
image.o: In function `exit_picture':E:\WinARM\bin/image.c:1327:
undefined refere
nce to `ftime'
_open_r.o: In function `_open_r':E:\WinARM\bin/_open_r.c:156: undefined
referenc
e to `device_table'
_read_r.o: In function `_read_r':E:\WinARM\bin/_read_r.c:84: undefined
reference
 to `device_table'
_close_r.o: In function `_close_r':E:\WinARM\bin/_close_r.c:71:
undefined refere
E:\WinARM\arm-elf\lib\libc.a(assert.o): In function
`__assert':assert.c:(.text+0
x24): undefined reference to `abort'
E:\WinARM\arm-elf\lib\libc.a(exit.o): In function
`exit':exit.c:(.text+0x28): un
defined reference to `_exit'
xt+0x110): undefined reference to `isatty'
Regards
Mithun
#1171189
It does. It can sometimes seem that people are in a panic, asking
questions of everyone and not apparently listening to the answers! I can
see how that would appear impolite. Every case on its merit I think; I
am undecided about this one ;-)
Clifford
A question of your own? This thread is over 20 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
