Forum: ARM programming with GCC/GNU tools sh.exe crash (WinARM Version 20060117)
I have experienced page faults on sh.exe when running make. It appears
that the issue is related to very long command lines (the particular
command line that caused the problems was a arm-elf-gcc invokation of
about 950 characters).
I experienced this on one machine, then it went away - I thought I'd
solved it by uninstalling Cygwin, but the problem reappered on another
machine. I suspect a buffer overrun or similar, hence the unpredictable
behaviour.
I replaced the sh.exe in the WinARM Version 20060117 distribution with
zsh.exe from http://unxutils.sourceforge.net/UnxUpdates.zip. This seems
to have solved the problem, but I have not tested it on a large sample.
I note that in the recent update you are now using MinGW. Probably wise,
but since it seems that I now have a stable toolchain, I'll stick with
it for now - unless anyone can give me a compelling reason to migrate?
Thanks for the great work BTW, getting rid of Cygwin dependency has
solved a number of issues for me.
Clifford
Author: Martin Thomas (Guest)
Thanks for the information.
Oh, I hope that it's not only "probably wise". I have got some
problem-reports for the previous WinARM-versions which could all be
solved with the mingw-tools. I have now decided to include the
mingw-Tools as default. WinAVR includes the mingw-tools too an a lot of
people use WinAVR so I guess it not a very unwise to follow them.
No problem if the old tools work for you, but I will stay with the
mingw-tools until there are new problems reported which are caused by
them. I will keep your suggestions about the unxupdates-zsh in mind.
Issues with the Cygwin-dependency have been one of the reasons to create
the first WinARM-collection. I'm glad that the WinARM-collection is
useful for you.
BTW: additional small examples for the WinARM-example-colletion are
always welcome for tests and as templates for own developments. I
currently do not own for example a STR7-board so some tested examples
for these targets would be a good. (And hitting the google-ads from time
to time is of cause welcome too...)
Martin Thomas
