EA DOG-M 162 + Atmega8
OP #1154232
• ▲ useful
▼ not useful
Hope users, don't mind if i create own thread in english language.
I've been trying to init display for 2 days but without any success..I
assembled another display with driver hd44780 and worked like charm..
I searched and read almost all threads dedicated to EA Dogs here.All i
got some errors or compiled programs with no effect to display..
The problem is i didn't handle the display too well,there's a little
scratch and i do really know if it's in working condition..
It's connected to atmega8 ( 4bit interface , 3,3V ) -> DB4-DB7 is
connected to PD0-PD3 and PD4 ->RS, PD5->E , PD6->R/W.
I prefer C-language.
All i need to know if display still works,if so, i'll spend some time to
customize the library for my needs.
Guest #1154251
• ▲ useful
▼ not useful
we have had the same problem a couple of weeks ago. I think you forgot
to connect pin PSB (I think it's pin 23) to VDD. This is absolutely
necessary for a communication in parallel mode. Otherwise, the display
expects data in serial mode.
And be carefull! I cracked two of this delicate parts during my attempt
to cut off the pin from a ground pad on the pcd...
If it still doesn't work: I can pick out a working code for you.
Regards,
Daniel
OP #1154267
• ▲ useful
▼ not useful
Thank you for quick reply.. PSB is connected to 3.3V.I checked the
scheme with datasheet..It should be good..
Pls post some working code..It makes me really mad these days..
By the way between pads CAP1N - CAP1P and Vout-Vin should be
electrolytic capacitors?
Here's my ea dog scheme to get a picture if something is not wronG..I
included atmega8 pins.
OP #1154549
• ▲ useful
▼ not useful
I replaced all PORTC with PORTD.. RS,R/W,E are connected as you
connected them..the only change i'm using portD.
Could you give me a hint what i should place in the main() to see
"hello" on the display?
I'm playing with the code..
int main()
lcd_init();
lcd_clear();
lcd_goto_xy(1,0);
lcd_write("hello");
return 0;
Guest #1154817
• ▲ useful
▼ not useful
Your main function is ok and should work. The parameters for
lcd_goto_xy() mean: x (0 to 15) is the column, y (0 or 1 on your
display) is the row. After calling lcd_init() the cursor is set to
coordinates (x,y)=(0,0). The display is also cleared during lcd_init().
So for just writing "hello" to the device it is enough to do the
following:
int main(void) {
  lcd_init();
  lcd_write("hello");
After this the cursor will be set to the coordinates (x,y)=(5,0), and
e.g. 6 calls to lcd_write("hello") will result in ..
hellohellohelloh
ellohellohello
Btw: I'm using different capacitors than you: VIN,VOUT: 2.2µF, CAP1N,
CAP1P: 1µF.
OP #1154889
• ▲ useful
▼ not useful
I'm desparate as i can declare..
Rik: Do you still got one of this displaY?I want to confirm mine is
dead.
I attached the code .Without any error but the display is still blank..
RS -> PD6
E  -> PD4
RW -> PD5
D7 -> PD3
D6 -> PD2
D5 -> PD1
D4 -> PD0
Pls tell me somebody the display is dead because i'm losing my patient
:) I can't take it out from breadboard.If i do so,the display break into
thousand peaces..
Guest #1154964
• ▲ useful
▼ not useful
Hi Martin,
I reviewed my code (3-line display) and made the necessary changes to
adopt it to your 2-line device. The changes are documented in the source
code. I also included the datasheet for the st7035 display controller.
Unfortunately I'm unable to test it, because I have no such 2-line
device.
Best regards
Rik
OP #1155075
• ▲ useful
▼ not useful
THank you..I checked with datasheet.It's clearly now..The INIT must be
good to interface in 4bit mode with 2 lines.
Im thinking that we do not coordinate with the signals RS,E,R/W. They
have to be set to work with display..
void lcd_enab(void);
void lcd_enab(void) {
  PORTD |= 0x10;
  _delay_us(40);
  PORTD = 0x00;
There's 2x lcd_enab which should be there..I wonder why compiler doesn't
signal there's duplicate.
What does this command do? PORTD |= 0x10; Its Bitewise OR... Portd =
Portd | 0x10.. It's something with E (because its connected to PD5)
Rik thank you for your advices !You've helped a lot..Now it's time to
get display working which i havent managed yet :D
Guest #1155136
• ▲ useful
▼ not useful
"void lcd_enab(void);" is the forward declaration, void lcd_enab(void)
{..} the function definition. The declarations for the other function
are stated in the header-file. The enable-function is not contained in
the header-file, because lcd_enable() shall not be part of the C-module
interface (only part of the implementation). According to the selected
compiler options you will get a warning about missing forward
declarations. For more info consult the ISO-C-standard and the gcc
manual.
> What does this command do? .."PORTD |= 0x10;"
Pull enable pin (E) high (1), without altering the other pins on the
port. This is the signal for the lcd-controller, that it can read the
data from the parallel port.
Guest #1155389
• ▲ useful
▼ not useful
Just tested your program on dogm163 (using my lcd_init, of course and
changed port d to c). Well.. it doesn't work :-/ Btw I found some
errors:
line 31: I guess this must be DDRD=0xFF or at least 0x7F.
line 121: "DDRD" !!!
