Hi everyone,
I’m looking into options for a custom FPGA link running at exactly 16.000 Gb/s NRZ through an SFP cage.
A 25G SFP28 rating doesn’t necessarily guarantee operation at this rate, especially if the module’s CDR only supports specific speeds. Has anyone found an optical module with documented 16 Gb/s support, either with CDR enabled or bypassed?
For a short connection, a passive SFP28 DAC seems worth considering because it has no retimer in the data path. SMA coax could also be an option with a suitable differential breakout. Either way, the FPGA transceiver and board routing would need to support the rate.
Which approach would you investigate first? Specific module numbers or test results with the FPGA and cable length would be helpful.
For background, our SFP module overview at ApexComponent covers the basics. I’m interested here in the less common 16.000 Gb/s case.
