Marantz PM8000 issue
OP #7997748
• ▲ useful
▼ not useful
Hi everyone! doing electronics since nearly 40 years now - but believe it or not: i joined the forum today...! Background is an issue w/ the Marantz PM8000 amp, being capable of switching between AB- and Class-A mode. Problem: The main (primary sided) fuse (3.15A/250V) gets destroyed, when connecting preamp w/ power stage. As long as the power stage is open, the fuse is OK - having no sound, of course. FYI: These two functional blocks are connected via two 100R resistors on each channel. Currently i do not have any ideas anymore... So i would be glad for any hint! Thanks Andi (lcdguru)
: Moved by Moderator
#7998025
• ▲ useful
▼ not useful
One of the many questions: Does the Powerstage work with another signal e.g. a signal generator when the premap is disconnected? If yes, did you observe the output of the preamp with an oscilloscpe yet?
: Edited by User
#8062963
• ▲ useful
▼ not useful
Andi K. wrote:
Hi everyone! doing electronics since nearly 40 years now - but believe it or not: i joined the forum today...! This looks like one of those cases where reviewing the schematic and verifying power distribution would be a good starting point. Many embedded issues ultimately come down to voltage stability or initialization timing. Components such as YKC22-0874V(https://www.jotrin.com/product/parts/YKC22_0874V) are often used in compact electronic assemblies where dependable operation is important. Background is an issue w/ the Marantz PM8000 amp, being capable of switching between AB- and Class-A mode. Problem: The main (primary sided) fuse (3.15A/250V) gets destroyed, when connecting preamp w/ power stage. As long as the power stage is open, the fuse is OK - having no sound, of course. FYI: These two functional blocks are connected via two 100R resistors on each channel. Currently i do not have any ideas anymore... So i would be glad for any hint! Thanks Andi (lcdguru)
If the fuse only blows when the preamp and power amp are connected, I'd check for DC offset or oscillation coming from the preamp. A scope measurement at the preamp output could reveal the culprit.
: Edited by User
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
