m1284p makes AVR Dragon "hang"?
OP #3156860
Hello all,
a few days ago I bricked two ATMega1284P's trying to use the Arduino IDE
with them (see
http://maniacbug.wordpress.com/2011/11/27/arduino-on-atmega1284p-4/). I
was using a USBasp clone from .cn (which worked for Arduino-on-ATTiny85,
btw).
The following takes place under Mac OS X 10.8.3 and (later, for the
Atmel Studio 6.1-part) Windows 7:
To unbrick I got myself an AVR Dragon and connected everything according
to the instructions here:
http://support.atmel.no/knowledgebase/avrstudiohelp/mergedProjects/AVRDragon/SCKT3100A3.htm
(checked the wiring and "direction" of the m1284p twice). See attached
picture.
Now, for the strange part: Inserting the m1284p into the TexTool (or the
board directly) makes the Dragon "hang", ie. it is unresponsive.
Without the 1284 avrdude works, but of course cannot talk to a device:
# avrdude -c dragon_pp -p m1284p -n -v -P usb
avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A20002xxxx
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        255
  firmware version:              7.33
  hardware version:              1
S_MCU:
  hardware version:              7
Serial number:                   00:a2:00:02:xx:xx
Device ID:                       AVRDRAGON
         AVR Part                      : ATMEGA1284P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
30
         PollValue                     : 0x53
31
         Memory Detail                 :
32
33
                                  Block Poll               Page                       Polled
34
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
35
36
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
37
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
38
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
39
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
40
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
41
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
42
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
43
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
44
45
         Programmer Type : DRAGON_PP
46
         Description     : Atmel AVR Dragon in PP mode
47
         Vtarget         : 5.0 V
48
         SCK period      : 1.00 us
49
50
avrdude: AVR device initialized and ready to accept instructions
51
52
Reading | ################################################## | 100% 0.15s
53
54
avrdude: Device signature = 0xffffff
55
avrdude: Yikes!  Invalid device signature.
56
         Double check connections and try again, or use -F to override
57
         this check.
58
59
avrdude: jtagmkII_close(): bad response to GO command: RSP_ILLEGAL_EMULATOR_MODE
60
61
avrdude done.  Thank you.
With the m1284p inserted, it goes dead on me:
avrdude: Version 5.11.1, compiled on Mar 26 2013 at 19:58:26
         Using Port                    : usb
         Using Programmer              : dragon_pp
avrdude: usbdev_open(): did not find any USB device "usb"
The same (though not as verbose ;) goes for Atmel Studio 6.1 under
Windows 7.
Any ideas what I could be doing wrong?
Thank you,
 Christian.
OP
To check if "everything else" works, I've tried the Dragon with an
ATTiny13A I found under the couch; things seem to be ok with this little
device:
# avrdude -c dragon_hvsp -p t13 -n -v -P usb
         Using Port                    : usb
         Using Programmer              : dragon_hvsp
M_MCU:
  hardware version:              1
S_MCU:
  hardware version:              7
         AVR Part                      : ATtiny13
         Chip Erase delay              : 4000 us
         PAGEL                         : P00
         BS2                           : P00
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
30
         CmdexeDelay                   : 25
31
         SyncLoops                     : 32
32
         ByteDelay                     : 0
33
         PollIndex                     : 3
34
         PollValue                     : 0x53
35
         Memory Detail                 :
36
37
38
39
40
           eeprom        65     5     4    0 no         64    4      0  4000  4000 0xff 0xff
41
           flash         65     6    32    0 yes      1024   32     32  4500  4500 0xff 0xff
42
43
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
44
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
45
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
46
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
47
48
         Programmer Type : DRAGON_HVSP
49
         Description     : Atmel AVR Dragon in HVSP mode
50
         Vtarget         : 5.0 V
51
52
53
54
55
56
57
avrdude: Device signature = 0x1e9007
58
avrdude: safemode: lfuse reads as 6A
59
avrdude: safemode: hfuse reads as FF
60
61
62
63
avrdude: safemode: Fuses OK
64
65
66
The error on the last line seems to be "known and ok", see
http://lists.gnu.org/archive/html/avrdude-dev/2009-11/msg00030.html for
more ("The attempt to send a CMND_GO command even in ISP mode is a
benign bug
that slipped in somehow in one of the recent releases.")
Good night,
 Christian.
A question of your own? This thread is over 13 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
