Interfacing/Initialising an ADXL312 with I2C
OP #2432499
• ▲ useful
▼ not useful
<< to those of you who already used the ADXL312 or similar >>
I have an SPI/I2C-Accelerometer (ADXL312) from Analog Devices which I
want to use in combination with an ATXmega128A1.
I have already successfully set up the I2C connection, but I cant get
any valid data from the x,y and z registers.
I can read the DEVICE_ID and my initialisation looks as follows:
DATA_FORMAT: 0x08
POWER_CTL: 0x08
INT_ENABLE: 0x80
After that, the only data I get from the X0,X1,Y0,.. registers are
those:
x00 xf0   X0,1
x00 xf0   Y0,1
x00 xf0   Z0,1
Does anyone know what might be the reason for that? Did I forget a part
of the initialisation?
OP #2432509
• ▲ useful
▼ not useful
BTW, this is a complete register dump, done with a multi-byte read.
xe5 x02 x00 x00    0:DEVID, R, R, R
x00 x00 x00 x00    4:R, R, R, R
x00 x00 x00 x00    8:R, R, R, R
x00 x00 x00 x4a   12:R, R, R, R
x82 x00 x32 x00   16:R, R, R, R
x00 x80 x80 x80   20:R, R, R, R
x00 x00 x00 x63   24:R, R, R, R
x00 x00 x00 x00   28:R, R, OFSX, OFSY
x00 x00 x00 x00   32:OFSZ, R, R, R
x00 x00 x00 x00   36:THRESH_ACT, THRESH_INACT, TIME_INACT, ACT_INACT_CTL
x00 x00 x00 x00   40:R, R, R, R
x0a x08 x80 x00   44:BW_RATE, POWER_CTL, INT_EN, INT_MAP
x02 x0b x00 xf0   48:INT_SOURCE, DATA_FORMAT, X0, X1
x00 xf0 x00 xf0   52:Y0, Y1, Z0, Z1
x00 x00           56:FIFO_CTL, FIFO_STATUS
R: Rerved/Not in use
OP #2458450
• ▲ useful
▼ not useful
Hey,
I solved the problem, I did a Design-Mistake with some 'Do-Not-Connect'
Pins ;)
You'll find my code in the attachment, in case someone or 'whatisthis'
will need it.. ;)
The twi_master_driver.* files are based on a AppNote from Atmel for the
XMEGA-TWI.
Cheers
