LPC2478: Using TFT Controller and I2S simultaneously
OP #1594004
Hi Guys,
Im wondering if it's possible to use the tft/lcd controller and i2s
controller at the same time.
The datasheet states
> Either the I2S function or the LCD function is selectable, see Table 13,
> Table 14, and Table 15.
(Tables are on page 66 in the LPC2478 manual)
But the I2S Pins (P[0]-P[9]) are only used, when the lcd controller is
configured for 24Bit TFT. Otherwise these pins seem to be free to use?
In the LPC24XX Manual (page 180) you can't choose between LCD controller
or I2S in the PINSEL register (PINSEL0). Both controller are mapped to
the secondary function.
But what does that mean? Is it possible to use 16Bit TFTs and I2S at the
same time? It should be possible from hardware side (pins are not
double-used by both modules).
Thanks in advance.
A question of your own? This thread is over 16 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
