Forum: Mikrocontroller und Digitale Elektronik avrdude liest lowfuse 0x00 highfuse 0x00 ext.fuse 0x00 auf Arduino Uno aus
von Alexander S. (alesi)
wenn ich auf die u.a. hier
Beitrag "Re: MEGA1284P XPLAINED über USB mit avrdudue programmieren"
beschriebene Weise versuche, mit avrdude die Fuses auf einem Arduino Uno
mit ATmega328P über USB (nicht ISP) auszulesen, erhalte ich drei Mal
0x00.
$ avrdude -p m328p -P /dev/ttyACM0 -c arduino -U lf:r:-:h -U hf:r:-:h -U ef:r:-:h -v
avrdude: Version 7.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is /etc/avrdude.conf
         User configuration file is /home/a.../.avrduderc
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : arduino
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                           Block Poll               Page                       Polled
30
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
31
32
           eeprom                 65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
33
           flash                  65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
34
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
35
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
36
           efuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
37
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
38
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
39
           calibration             0     0     0    0 no          1    1      0     0     0 0x00 0x00
40
41
         Programmer Type : Arduino
42
         Description     : Arduino for bootloader using STK500 v1 protocol
43
         Hardware Version: 3
44
         Firmware Version: 4.4
45
46
avrdude: AVR device initialized and ready to accept instructions
47
avrdude: device signature = 0x1e950f (probably m328p)
48
avrdude: reading lfuse memory ...
49
avrdude: writing output file <stdout>
50
0x0
51
avrdude: reading hfuse memory ...
52
53
0x0
54
avrdude: reading efuse memory ...
55
56
0x0
57
58
avrdude done.  Thank you.
Das können ja nicht die richtigen Fuse-Werte des ATmega328P sein.
von Arduino F. (Firma: Gast) (arduinof)
Ich kann nur bestätigen, dass dem so ist.
Versuche es mal langsamer mit: -B20
Das hilft nicht!
Denn die Kommunikation mit dem Bootloader tuts ja.
Es ist der 256 Worte große opti Bootloader auf dem UNO und der kann
weder Fuses lesen, noch das EEPROM lesen oder beschreiben.
Also kann ich dem TO nur beipflichten:
Es ist so, wie es ist.
Wenn ihm das nicht passt, braucht es einen ISP Adapter, oder ihm spielt
ein Programm auf den UNO welches die Fuses liest.
Das Ganze ist allerdings auch unsinnig, da die Fuses des UNO µC auch in
der boards.txt notiert sind. Man also dort nachlesen kann.
von Wastl (hartundweichware)
Warum einfach wenn es auch umständlich geht ....
Also ich verwende einen beliebigen ISP Programmer der von
AVR Studio oder Atmel Studio angesprochen werden kann.
Damit kann ich nach Belieben und recht komfortabel jede
einzelne Fuse setzen oder löschen. Und brauch nicht mal
einen Fuse Calculator (noch so ein Umstands-Kram). Denn
AVR Studio oder Atmel Studio sagt mir zu den Fuses alles
was ich brauche bzw. wissen muss.
Ansonsten bleibt zu zitieren:
Beitrag "Re: Timing-Problem"
Arduino F. schrieb:
> Das hilft nicht!
Ich dachte, er verwendet einen Arduino als ISP Programmieradapter. In
dem verlinkten Thread wurden die Fuses schließlich auch über ISP
ausgelesen.
Mit dem Bootloader kann man Fuses weder lesen noch ändern. Da stimme ich
dir zu.
Wie geschrieben, der (Linux) PC war nur über USB direkt mit dem
USB-Anschluss des Uno verbunden und als programmer in avrdude war "-c
arduino" ausgewählt. D.h. der bootloader kann wirklich nur Programme
hochladen (und ggf. auslesen) und sonst nichts. Ok. Mir ist schon klar,
dass ich die Fuses per ISP mit einem Atmel ICE oder AVR ISP MkII
auslesen kann.
P.S. Falls avrdude erkennen kann, dass ein bootloader vorhanden ist und
die Fuses nicht gelesen werden können, wäre evtl. eine Info dazu in der
Ausgabe hilfreich.
Kann avrdude in diesem Fall nicht, denn der Bootloader simuliert einen
STK500 kompatiblen ISP Programmieradapter.
Der Arduino UNO Bootloader emuliert einen Teil des STK500V1 Protokolls.
Und darum kann AVRdude das auch nicht erkennen.
Andere Bootloader, z.B. der des Mega kann deutlich mehr Funktionen, ist
dafür allerdings auch 4 mal so groß.
Tipp:
Falls dir nicht schmeckt, was der UNO Bootloader kann/macht, könntest du
den alten vom Nano mal aufspielen und es nochmal versuchen.
Arduino F. schrieb:
> Tipp:
Danke für den Tipp aber ich habe gelernt, dass bootloader doch sehr
eingeschränkt und spezifisch sind, siehe
