Forum: Mikrocontroller und Digitale Elektronik Hilfe gesucht bei einer Meldung des Compilers XC8
von Michael S. (misax)
hallo;
folgende Meldung bekomme ich beim Compilieren. kann mir jemand kurz und
bündig sagen, was ich tun muss, um sie zu beheben ?
"C:\Program Files\Microchip\xc8\v2.40\bin\xc8-cc.exe"  -mcpu=16F884 -c
-mdfp="C:/Program
Files/Microchip/MPLABX/v6.00/packs/Microchip/PIC16Fxxx_DFP/1.3.42/xc8"
-fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore
-xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default
-msummary=-psect,-class,+mem,-hex,-file  -ginhx32 -Wl,--data-init
-mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits
-mno-download -mno-stackcall -mdefault-config-bits   -std=c99 -gdwarf-3
-mstack=compiled:auto:auto     -o build/default/production/newmain.p1
newmain.c
::: advisory: (2049) C99 compliant libraries are currently not available
for baseline or mid-range devices, or for enhanced mid-range devices
using a reentrant stack; using C90 libraries
make[2]: *** [build/default/production/newmain.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
mein Programm
#include "my-configs.h"
#define _XTAL_FREQ 4000000
#define I2C_BaudRate           100000
#define SCL_D                  TRISC3
#define SDA_D                  TRISC4
#define LCD_BACKLIGHT          0x08
#define LCD_RETURN_HOME        0x02
#define LCD_TYPE               2
#define LCD_TURN_ON            0x0C
#define LCD_CLEAR              0x01
#define LCD_ENTRY_MODE_SET     0x04
unsigned char i2c_add;
unsigned char RS, i2c_add, BackLight_State = LCD_BACKLIGHT;
void main(void) {
  SSPCON  = 0x28;
  SSPCON2 = 0x00;
  SSPSTAT = 0x00;
  SSPADD = ((_XTAL_FREQ/4)/I2C_BaudRate) - 1;
  SCL_D = 1;
  SDA_D = 1;
30
31
  i2c_add = "0x4E";
32
33
  IO_Expander_Write(0x00);
34
  __delay_ms(30);
35
  LCD_CMD(0x03);
36
  __delay_ms(5);
37
  LCD_CMD(0x03);
38
  __delay_ms(5);
39
  LCD_CMD(0x03);
40
  __delay_ms(5);
41
  LCD_CMD(LCD_RETURN_HOME);
42
  __delay_ms(5);
43
  LCD_CMD(0x20 | (LCD_TYPE << 2));
44
  __delay_ms(50);
45
  LCD_CMD(LCD_TURN_ON);
46
  __delay_ms(50);
47
  LCD_CMD(LCD_CLEAR);
48
  __delay_ms(50);
49
  LCD_CMD(LCD_ENTRY_MODE_SET | LCD_RETURN_HOME);
50
  __delay_ms(50);
51
52
    TRISA2 = 0;
53
54
    while(1) {
55
56
    #include "my-loop.h"
57
58
59
60
return;
61
62
63
64
void IO_Expander_Write(unsigned char Data)
65
66
  I2C__Start();
67
  I2C__Write(i2c_add);
68
  I2C__Write(Data | BackLight_State);
69
  I2C__Stop();
70
71
72
void I2C__Start()
73
74
    I2C__Wait();
75
    SEN = 1;
76
77
78
void I2C__Wait()
79
80
    while ((SSPSTAT & 0x04) || (SSPCON2 & 0x1F));
81
82
83
unsigned char I2C__Write(unsigned char data)
84
85
    I2C__Wait();
86
    SSPBUF = data;
87
    while(!SSPIF);  // Wait Until Completion
88
  SSPIF = 0;
89
    return ACKSTAT;
90
91
92
void I2C__Stop()
93
94
    I2C__Wait();
95
    PEN = 1;
96
97
98
void LCD_CMD(unsigned char CMD)
99
100
  RS = 0; // Command Register Select
101
  LCD_Write_4Bit(CMD & 0xF0);
102
  LCD_Write_4Bit((CMD << 4) & 0xF0);
103
104
105
void LCD_Write_4Bit(unsigned char Nibble)
106
107
  // Get The RS Value To LSB OF Data
108
  Nibble |= RS;
109
  IO_Expander_Write(Nibble | 0x04);
110
  IO_Expander_Write(Nibble & 0xFB);
111
  __delay_us(50);
112
von Thomas Z. (usbman)
  while(1) {
das ist ziemlich sicher Unsinn
von Nop (Gast)
Wenn's keine C99-Libs gibt, compilier das Programm halt als C90:
-std=c90 statt -std=c99.
danke nop. wo kann ich -std=c90 einstellen ?
gar nirgens, das ist auch nicht notwendig weil das nur ein Hinweis ist
und keine Fehlermeldung.
Der Fehler ist an einer Stelle die du nicht zeigst. Vermutlich gibt es
my-loop.h überhaupt nicht-
Den Miniloop auszulagern war nur ein Test. Auch wenn die 4 Zeilen direkt
drinstehen kommt der Fehler.
Ich versuchte die einzelnen Routinen aus einer I2C-Bibliothek direkt in
den Source-Code zu kopieren, aus irgendeinem Grund kommt dann der
Fehler.
Ich versuche mal den Code zu minimieren und die genau erste Zeile
herauszufinden wenn der Fehler auftaucht.
aber hier nochmal der derzeitige Code.
#define LCD_TYPE               2
void main(void) {
  SSPCON  = 0x28;
  SSPCON2 = 0x00;
  SSPSTAT = 0x00;
  SCL_D = 1;
  SDA_D = 1;
30
31
  i2c_add = "0x4E";
32
33
34
35
36
37
38
  __delay_ms(30);
39
  LCD_CMD(0x03);
40
  __delay_ms(5);
41
  LCD_CMD(0x03);
42
  __delay_ms(5);
43
  LCD_CMD(0x03);
44
  __delay_ms(5);
45
46
  __delay_ms(5);
47
48
  __delay_ms(50);
49
50
  __delay_ms(50);
51
  LCD_CMD(LCD_CLEAR);
52
  __delay_ms(50);
53
54
  __delay_ms(50);
55
56
57
58
59
    TRISA2 = 0;
60
61
    while(1) {
62
63
        RA2 = 1;
64
        __delay_ms(1200);
65
        RA2 = 0;
66
        __delay_ms(1200);
67
68
69
70
return;
71
72
73
74
75
76
77
  I2C__Start();
78
79
80
  I2C__Stop();
81
82
83
void I2C__Start()
84
85
    I2C__Wait();
86
    SEN = 1;
87
88
89
void I2C__Wait()
90
91
92
93
94
95
96
    I2C__Wait();
97
    SSPBUF = data;
98
99
  SSPIF = 0;
100
    return ACKSTAT;
101
102
103
void I2C__Stop()
104
105
    I2C__Wait();
106
    PEN = 1;
107
108
109
110
111
112
113
114
115
116
117
118
119
  Nibble |= RS;
120
121
122
  __delay_us(50);
123
von Nop (Gast)
> den Source-Code zu kopieren aus irgendeinem Grund kommt dann der Fehler.
Weil diese Routinen Variablen / Definitionen z.B. aus deren Header-Files
verwenden, die Du nicht mit rüberkopiert hast.
von Volker S. (vloki)
Welcher Fehler?
Der Compiler übersetzt die Sourcedatei einfach vom Anfang her. Wenn er
auf irgendwas stößt, was ihm (noch) nicht bekannt ist, dann ist
Feierabend.
Er kann zum Beispiel mit Funktionsaufrufen in main() nichts anfangen,
wenn diese Funktionen erst später in der Datei implementiert werden!
-> https://de.wikipedia.org/wiki/Funktionsprototyp#Hintergrund
