You may wonder what is APA107 leds? Actually it's an updated version of apa102, more faster and more stable. It can be the only leds in the market now which can replace apa102 in Taiwan. If want to know more information or know more please visit www.aevalighting.com, or email to info@aevalighting.com. Here let see some features below: APA107 LED Chip 1. Product Overview : APA107 is a product which containing a signal decoding module, data buffer, a built -in constant current circuit and RC oscillator; CMOS, low voltage, low power consumption; 256 level gray scale PWM adjustment and 32 brightness adjustment; use the double output, Data and synchronization of the CLK signal, connected in series each wafer output action synchronization. 2. Main Application Field: ● Full color LED string light, LED full color module, LED super hard and soft lights, LED guardrail tube, LED appearance / scene lighting ● LED point light, LED pixel screen, LED shaped screen, a variety of electronic products, electrical equipment etc.. 3. Description: ● Top SMD internal integrated high quality external control line serial cascade constant current IC; 5V application; default on electric lights; ● Control circuit and the RGB chip in SMD 5050 components, to form a complete control of pixel, color mixing uniformity and consistency; ● The two-wire synchronous control. ●The three RGB output control, 8Bit (256) color; 5Bit (32) to adjust the brightness; ● The three constant current drive, self detection function specific signal ● The maximum frequency of 30MHZ serial data input ● The double data transmission, built-in support uninterrupted oscillation PWM output, can maintain a static image.
