Forum: FPGA, VHDL & Verilog FPGA in CPU socket
Author: James Yunker (Company: Naval Undersea Warfare Center) (newport_j)
Posted on:
0 useful
I am very new to FPGAs, but my main interest is in using the FPGA to
occupy the second CPU socket in a dual CPU mothboard.
I am not even sure what an FPGA development board is compared to just an
FPGA board.
Do you program on one board and then port code to another board, i.e.
the FPGA board that the program will eventually run on?
I assume that programming for a given FPGA is the same no matter how it
is connected to the motherboard.
Also, what about Alpha Data, Inc. I read somewhere where they connect
the FPGA to the motherbaord through the motherboard memory. Is this
true?
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
: Edited by Admin
Author: Lothar Miller (lkmiller) (Moderator)
Posted on:
0 useful
James Yunker wrote:
> using the FPGA to occupy the second CPU socket in a dual CPU mothboard.
That is not the usual way, because it is a very hard way. You will have
to mimic the behavior of the CPU very detailed.
Which one?
> FPGA board.
Its the same. It depends just on the connectors whether you can use a
specific FPGA board for your application.
The usual and most portable way to access the CPUs memory is by using
DMA via PCI or PCIe.
Author: A.K. (Guest)
Posted on:
0 useful
A normal PC mainboard? Could get a bit hard, unless the sockets still
have conventional buses. For Intel, this era ended after the Core 2, for
AMD at K7/K8.
To communicate with the system you'll likely need a bit more
documentation that you might be able to find publicly. IIRC neither
Intel QPI nor AMD Hypertransport is fully documented publicly concerning
communication between CPU sockets. Besides that those links are damned
fast.
Posted on:
0 useful
Going to PCI puts me back in the jam of constricted data passage when I
tried CPU-GPu programming.
It limits what can be passed and it does take time (do not forget that
data  must travel to the GPU and back to the CPU for a round trip) that
is two passes across the CPU-GPU bus; think of the time.
I again am interested in the arragement that allows the FPGA to reside
on the motherboard in the spare CPU sockett. This of course requires a
motherboard with two CPU sockets. Thay do make them - check out NUWEGG.
If I cannot have that then interface with the DDR3 memory is my next
choice. I just do not think that the PCI interfcae offers any
advantages.
thanks in advance.
Respectfully,
Newport_j
PS. Nallatech and DRC Computer (to name a few) offer motherboards with
an FPGA situated in the spare CPU socket on a dual CPU socket
motherboard.
As I said, I am very new to this technology (FPGAs), but the items that
I have read make a big deal out of placing the CPU on the motherboard.
It has the fastest speed and the largest bandwidth. That sounds great to
me.
Author: A. K. (prx)
Posted on:
0 useful
Yes, PCI is outdated. Why not PCI Express?
Author: Lattice User (Guest)
Posted on:
0 useful
> motherboard.
On the Nallatech Website i can only find PCI Express based Solutions,
can you point us to a CPU Socket Solution?
> me.
As A.K. has pointet out with actuell CPU's you are out of luck. One
reason is that a northbridge connected to a FSB (front side bus) of the
CPU is a thing of the past.
But feel free to point us to an actuell product and prove us wrong.
Author: A. K. (prx)
Posted on:
0 useful
James Yunker wrote:
> Nallatech
Didn't find a MB there.
> and DRC Computer
Found a socket F mainboard. Not exactly high end for todays standards,
and the bandwidth probably isn't a lot faster as todays PCI Express
links.
Since top bandwidth appears to be your concern: Do you think you can
master interconnects clocked at about 3GHz (Intel QPI), x2 for data
rate, regarding layout and FPGA design?
: Edited by User
Posted on:
0 useful
According to
http://en.wikipedia.org/wiki/Intel_QuickPath_Interconnect
Intel QPI has a raw datarate of 12.8 GByte/s in one direction, roughly
the same as PCIe Gen3 x16 after the protocoll overhead. PCIe also can
receive and transmit at the same time.
Author: A. K. (prx)
Posted on:
0 useful
And with PCIe he may have a chance to find some FPGA having a PCIe
interface module included. I don't think such a beast exists for QPI.
But actually I wanted to point out, what interface clock rates he'll
have to deal with in such a design. Not for the faint of heart.
: Edited by User
Posted on:
0 useful
You  know that you bring up an interesting point here. I saw the adds
for a FPGA on a motherboard in the context of a summary report written
.... well, I do not know when. That is teh problem.
It did spark my interest. As I said, I have been struggling with
bandwidth issues on my CPU-GPU interface connection. When I saw this
report I became interested. It seems to answer most if not all of my
problems.
But no one gave a date on this report that I read. After talking with
some vendors (Nallatch, Altera, Xilinx and Xtremedata) I was concerned
that while this FPGA on the motherboard CPU slot is out there nobody is
pusshing it now - or so it seems.
My guess then was that it is an old and unsuccessful technology. In
other words in came and went. I did see something last week that may
support that.
Their arguement was FPGA manufacturers on the motherboard second CPU
slot for two reasons do do it anymore. They reasons are:
1. The CPU slot on the motherbaord is always changing;
2. The second slot on a motherboard is disappearing since if you want
more cores in you system just buy a CPU (either Intel of AMD) with more
cores. Don't bother to add a second CPU; it is just not neccessary
anymore.
Anyway that is where I am. Anything that has to do with PCI gets a
thumbs down from me since that is the interface that I struggled so
mightily with in my CPU-GPU setup.
Maybe I am wrong and betting on the wrong setup. I know that HFT techs
use my system setup. Maybe no one else does.
As I said is this setup around. Also what are the benfits of PCI over
PCIe?
Thanks in advance.
Respectfully,
Newport_j
Author: A. K. (prx)
Posted on:
0 useful
James Yunker wrote:
> Also what are the benfits of PCI over PCIe?
Slow enough to be easily implemented. ;-)
Author: Achim S. (Guest)
Posted on:
0 useful
you can find a description of the Nallatech MB-system here:
http://www.nallatech.com/Intel-Xeon-FSB-Socket-Fil...
Author: A. K. (prx)
Posted on:
0 useful
Roughly the same technological age as the old Opteron system from DRC
above. Has Intels old conventional front side bus.
: Edited by User
Author: A. K. (prx)
Posted on:
1 useful
Which kills such a product as soon as the socket changes. PCIe however
survives.
Only in desktops/workstations. There still are many multi-socket
servers.
AMD wanted to sell Hypertransport as a bus for highspeed
peripherals/coprocessors, even had its own HTX connector, though this
was at a time when the highend buses were big PCI-X. Wasn't really
successful though.
Talking about PCI oder PCIe? They are quite different. More exactly, PCI
and PCIe have nothing in common, at phys layer. Don't confuse PCIe with
PCI-X which is wider and faster PCI.
: Edited by User
Posted on:
0 useful
Xeon FSB is end of live:
http://ark.intel.com/products/series/28355/Intel-X...
In other words outdatet.
Without understanding what exactly the bottleneck is im this setup your
conclusion is premature. PCIe Gen3 x16 (as with modern GPUs) is much
faster than the old Xeon FSB setup. If your CPU-GPU setup is slow it is
most likely to a bad software setup or a limitation of the GPU
architecture. Both don't apply to a PCIe implementation on a FPGA.
Posted on:
0 useful
Let me ask this. The HTX slot on a AMD comaptible motherboard is a
location where one can place an FPGA provide it (the fpga) is slot
compatible.
Is the HTX slot just a CPU slot or is it a special slot just for things
like an FPGA? I do not mean to imply the HTX slot is exclusively for
FPGA.
Also, the Intel FSB format is nearing end of life so I can ignore it.
Thanks in advance.
Respectfully,
Newport_j
Author: A. K. (prx)
Posted on:
0 useful
> like an FPGA?
It is (was) intended for a high bandwidth low latency peripheral or
coprocessor, not für a general purpose CPU. However the distinction
between peripheral and processor is largely arbitrary at this level,
except for cache coherency traffic.
: Edited by User
Author: Grendel (Guest)
Posted on:
0 useful
Are you sure that the problem is too low datarate between CPU-GPU and
not the architecture of your software?
If this is really the problem, maybe it is different with an FPGA - as
you might be able to move some of the processing that is now done on the
CPU over to the FPGA - if it is suitable for that.
(there are also FPGAs with on-chip ARM Cortex Cores...)
Author: Newport_j (Guest)
Posted on:
0 useful
The Intel FSB format is now reaching end of life? What is taking its
place?
Thanks in advance.
Respectfully,
Newport_j
Author: A. K. (prx)
Posted on:
0 useful
> place?
It reached end of life years ago.
Memory is attached directly, peripherals are either connected directly
by PCIe links or are part of the system- and interprocessor
communication structure which uses QPI point to point links. Though the
links are techically different, the overall structure is the same with
Intels QPI and AMDs Hypertransport.
AMD developed this system communication concept a decade ago with the
K8, Intel followed years later. It is no longer possible to run parallel
multidrop buses at the required speed, so partially serialized point to
point links running at very high speed were becoming necessary.
Simplified, todays multi-socket servers looks somewhat like several
processors having local memory, and one or more i/o-hubs, connected
together by a meshed serial network instead of parallel buses. Think of
a room with single socket PCs and separate peripheral devices, all
connected by a packetized network, pretending to be a single system. As
a result, bandwidth and access time of memory are no longer uniform, but
instead depend on the exact path between cpu and memory.
: Edited by User
Posted on:
0 useful
Intel QPI on Virtex 7:
http://press.xilinx.com/2012-09-11-Xilinx-Demonstr...
That was on a Sandy bridge, actual CPUs have a higher clockrate on the
QPI.
(8 GHz vs 3.1 GHz)
Posted on:
0 useful
Lattice User wrote:
> (8 GHz vs 3.1 GHz)
Typo: must be (8 GHz vs 3.2 GHz)
Posted on:
0 useful
One more Correction about the Speed, the Intel datasheets are bit
sparse:
The Xilinx Demo was on an Ivy bridge CPU (Xeon E5 2600 v2).
This runs with 6.4 GT/s (forward Clock 3.2 GHz).
Youtube-Video "7 Series FPGA Demonstration of Intel QPI Protocol"
Actuell Xeon E5 4600 v2 perfomance is 8.0 GT/s (forward Clock 4 GHz).
Posted on:
0 useful
I am unsure where to begin this endeavor - for want of better term. I do
not know what FPGA boad to get first. A develpopment board?
I feel that there is a good chnance that I will buy a board and find out
later it does not meet my needs. I have a very specific plan of speeding
up one very long complex c program so I do not think my needs are vague.
They  is specific.
Would a Nios Embedded Evaluation Board (NEEK) do it? It seems with thta
you can try many boards with a NEEK and decide which one that you want.
Respectfully,
Newport_j
Posted on:
0 useful
This looks old - Cyclone 3 is how old, a decade or so?
Better go for the latest generation. And if you want to run C code on
the FPGA and accelerate portions of it - again: Look at the devices with
embedded ARM Cortex Cores (Xilinx Zynq or the respective Altera
devices).
Author: Uwe (Guest)
Posted on:
0 useful
You should think about GPGPU with OpenCL or CUDA.
Posted on:
0 useful
I have it is just CPU-GPu bus constricted. It wil not work given the
present state of technology in GPUs.
Respectfully,
Newport_j
Posted on:
0 useful
devices).
Please give me a link. It would be very helpful.
Thanks in advance.
Respectfully,
Newport_j
Posted on:
0 useful
http://www.xilinx.com/products/silicon-devices/soc...
Xilinx itself has some nice PCIe Boards (but there are lots of other
boards):
http://www.xilinx.com/products/boards-and-kits/EK-...
I could guess that you need some aquisition as well in you application,
FMC Cards are nice for this:
http://www.xilinx.com/products/boards-and-kits/1-45SL7B.htm
Posted on:
0 useful
> Respectfully,
> Newport_j
Can you tell us what data rates (in MBytes/second or GBytes/second) you
are looking for, also what you can currently achieve with the GPU and
your application.
Posted on:
0 useful
your application.
I am sorry. I cannot do that. The information is not available any more.
It is just not available.
I know from using the Portland Group C compiler that the code was
calculation and memory bound. Many for loops had independent
interations, but there was just not enough iterations in a loop to
justify sending calcuation to GPU and then sending them back afterwards
to the CPU. That sending to GPU and sending back to CPU takes time.
The secret to speeeding up my program is parallelism. When I increased
the number of cores the program uses when it runs - it executed faster.
It was almost linear - double the cores and halve the execution time.
I only had 8 cores so this could only go up to 8. All the software that
I used to determine program scalability suggested this can continue if I
kept on doubling the number of cores. I could not.
So instead of waiting for processors with more than 8 cores being
available on PC desktops, I looked into FPGAs.
They seem ideal for my job. They are very paralleizable. Thtat is what I
need.
Respectfully,
Newport_j
Author: Joseph (Guest)
Posted on:
0 useful
Hi,
Any update in the discussion?
Dose any body contact with xilinix customer service about price of QPI
SmartCORE IP?
http://www.xilinx.com/esp/datacenter/data_center_ip.htm
System Interconnect   QuickPath Interconnect (QPI)
    -Designed for High-speed FPGA-to-processor communications
    -Cache agent, with full-width (20 lanes) operation at 6.4Gbps per
lane
    -Example design, for rapid start-up, based on Xilinx® Virtex®-7 FPGA
Entering an e-mail address is optional. If you want to receive reply notifications by e-mail, please log in.
Rules — please read before posting
  • Post long source code as attachment, not in the text
  • Posting advertisements is forbidden.
Formatting options
  • [c]C code[/c]
  • [avrasm]AVR assembler code[/avrasm]
  • [vhdl]VHDL code[/vhdl]
Bild automatisch verkleinern, falls nötig
Note: the original post is older than 6 months. Please don't ask any new questions in this thread, but start a new one.
