Forum: FPGA, VHDL & Verilog for loop in verilog code
von nelson g. (Company: student) (together)
useful
I have written a verilog code using 'for' loop..My aim is to display
2,3,4 in three consecutive clock cycle.But for the first clock cycle
itself,my 'for' loop is executing fully and showing output as 4.How can
I avoid this??
(I studied that for loop will execute sequentially only.But I am not
getting output sequentially.)
I am including my code below...Plz help me...
module for_test(clk,n,m); //programe for testing the for loop
input clk;
output [7:0] m;
output n;
reg [7:0] m;
integer n;
always @(posedge clk)
begin
for(n=2;n>=0;n=n-1)
begin
if(n==2)
begin
m <=8'h02;
end
else
if(n==1)
begin
m <=8'h03;
end
else
if(n==0)
begin
m <=8'h04;
end
end
end
endmodule
von hiall (Guest)
useful
every step in the for loop is workin parallel
useful
But how??for loop is a sequential statement!!
von 4321 (Guest)
useful
The for statement is executing sequentially but within one clock cycle
as you coded it above.
It should be completely forbidden for beginners to use any loop
statements in Verilog or VHDL because they won't do what you'd expect
from a programming language.
What you want to be implementing is a counter. Search the internet,
there are thousands of examples how it works. http://www.asic-world.com/
contains a lot of examples.
useful
ok..then how can i modify the above program so that the for loop will
execute only one iteration for each clock.....
PLZ help me....thanks for ur reply
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
useful
YOu must implement a counter and then select one of the output values
according to the counters value:
1
reg [7:0] m;
2
reg [1:0] n := 2'h02; -- initialize the counter
3
4
always @(posedge clk) begin
5
  n <= n-2'h01;       -- thats the counter
6
  if(n==2'h02) begin
7
    m <=8'h02;
8
  end
9
  if(n==2'h01) begin
10
    m <=8'h03;
11
  end
12
  if(n==2'h00) begin
13
    m <=8'h04;
14
  end
15
end
I'm sorry, if the code doesn't work directly (I'm a VHDL fellow), but
hopefully you get the idea...   ;-)
useful
So i want to replace my for loop with if statement..
Is there any method to use for loop itself??
That means any logical method that execute one iteration of a for loop
in one clock cycle???
useful
No, you must replace it by a state machine! Everything in hardware
(FPGA) that has a "one after the other" must be a state machine. And the
most simple kind of a state machine is a counter, counting one step
after the other...
Not for that, waht you want to do.
You can use a loop e.g. if you want to write only one inverter (or
something else) and you want to get lots of inverters in parallel on
the FPGA...
useful
> after the other...
> the FPGA...
Actually above code is only a sample...I want to include a block of
statements in each iteration that i want to execute sequentially in each
clock cycle..If i go for state machine i want to replicate my code for
each state and code length become very large...Thats why i am asking
about for loop that execute sequentially like a state machine!!!
useful
> Thats why i am asking about for loop that execute sequentially
To keep things short: such a loop does not exist.
> I want to include a block of statements in each iteration that i want
> to execute sequentially in each clock cycle..
What is your actual problem?
useful
In my design all the iterations of for loop is  executing in one clock
edge....
I want a for loop which will execute one iteration in one clock
edge...That means in first rising edge of clock,it should execute first
iteration of for loop.In second rising edge of clock,it should execute
2nd iteration of for loop like wise it should continue....
thanks for ur replies!!!!
useful
> I want a for loop which will execute one iteration in one clock edge...
Then you can't use Verilog.
Because loops in Verilog don't offer the desired behaviour!
To say it in a different way: a loop in Verilog is not capable to do
what you want.
> edge....
Thats exactly the way a loop in Verilog is expected to work.
Is it really that hard to understand?  :-o
I already told the solution everybody else in the world uses: FSM
https://www.google.de/search?q=verilog+fsm
von Blue (Guest)
useful
Im trying to write a verilog code for this expression as an assignment..
anyone who knows about it please help.. thanks in advance
von Blue (Guest)
useful
> assignment..
for i=1:H
        for j=1:W
            k(i,j) = (1-(2*i/(R*H)-1/R)^2-...
                (2*j/(R*W)-1/R)^2);
            if k(i,j) < 0
                k(i,j) = 0;
            end
        end
    end
end
von flipflop (Guest)
useful
dls
von Shahid (Guest)
useful
how to fix my error 1440 in verilog code
useful
Read about "loops in Verilog". They do not what you (or any other
C-programmer) expect...
Try it with a fixed range in the loop and terminate the loop
prematurely.
BTW: it is a very, very clever idea to post source code NOT as a
screenshot. It is very, very difficult to apply some changes or even
copy a line out of that kind of "code".
BTW2: pls start a NEW thread for a NEW question.
BTW3: did you read the thread ahead of your post. Did you read the thing
about the different behaviour of loops?
von Luciano (Guest)
useful
input clk;
output [7:0] m;
output [2:0] n;
reg [7:0] m;
reg [2:0] n;
 if (n>0) n <= n-1;
 case(n)
  2: m <= 2;
  1: m <= 3;
  0: m <= 4;
 endcase
end
initial begin
 n = 2;
end
endmodule
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
