Forum: FPGA, VHDL & Verilog Error loading design (Modelsim student version)
Author: Keltuzad (Guest)
Posted on:
0 useful
Hi @ all,
Im working with the student version of Modelsim, I have dowloaded the
latest version (6.5b) and the licence and copied it to the root
folder(C:\dev\Modeltech_pe_edu_6.5b).
Now to the problem:
Im using "vsim -voptargs=+acc work.tdm_bert_tb" as my run command.
My only error report is:
#Error loading design
Due to the limited content of the error msg I have difficulties finding
a solution.
What have I already done:
I have reinstalled Modelsim + licence with Administrator rights, tried
running it with different -commands e.g. vsim -optargs work.tdm_bert_tb,
vsim work.tdm_bert_tb (none).
I only recieve the above mentoinened error.
Any suggestions are welcome.
Thanks in advance.
Kel.
: Moved by Admin
Author: guest (Guest)
Posted on:
0 useful
did you compile your designfiles/tb into the work lib using vlib and
vcom?
Author: Kel (Guest)
Posted on:
0 useful
hi,
yes all files including the testbench are compiled.
Author: Christian R. (supachris)
Posted on:
0 useful
In the most cases the error is shown many lines obove the "Error loading
design" Message. Search the blue lines for "Fatal : ..." or so.
Author: Kel (Guest)
Posted on:
0 useful
Hi supachris,
thx for the hint but the only error line I recieve is the "#Error
loading design" line and no other output. This is the fact that keeps me
from investigating further.
Author: Anand Singh (Guest)
Posted on:
0 useful
I am getting the error "Error Load Design"(Modelsim student version).
I have three modules and all are compiling without errors.
However,the order for one of them (test bench) stays '0' in the left
window.
Now,while trying to run the three modules,I was getting the error which
I have specified above.
Author: Ottmar (Guest)
Posted on:
0 useful
If the topmodule isn't loadable, try the submodules one by one.
Author: Sentinel (Guest)
Posted on:
0 useful
Make sure that your PDF student license is contained in the
C:\Modeltech_pe_edu_10.0c' directory folder only( i.e. is not contained
in any subfolders, the 'win32pe_edu' folder in particular!). I tried
this before and it cured the #Error loading system# for me when it
appeared!
I hope this will cure some headaches aswell!
Regards,
Sentinel.
Author: Victoria (Guest)
Posted on:
0 useful
Hi,
I just had the same error message myself
and this is how I fixed it
- Check your license is not in a sub folder especially 'win32pe_edu' in
the  ModelSim directory
- and then check your "tb" design to see if your "module" and "uut" name
are one and the same for example mine was
         module tb_ex1_gate();
and
         ex1 uut
This led to the error "#Error loading design" because ModelSim could not
find it in the libraries, it should have been
and
         ex1_gate uut
also when the this error appears you can find more detail when you
scroll up on the Transcript section
I hope all this helps I am using ModelSim PE Student Edition 10.0c
Author: BVP (Guest)
Posted on:
0 useful
Thanks, Christian. Your input has helped me! Cheers..
Author: Anuj K. (anuj_k)
Posted on:
0 useful
Guys I solved my problem!
But first lets describe the problem
I was building a half subtractor using structural modelling. One of the
components used a not gate and I named the component "NOTGATE", which
was okay since it compiled peacefully.
But when i simulated the entity, an error occurred that said "Error
loading Design".
I ran a google search and stumbled here. The guy named Christian on this
post pointed out to check the lines above the error "FATAL...". Thanks
christian!
I checked mine out and it said that the "entity" NOTGATE was causing
problem which was in the same folder as the entity of half subtractor. I
checked the folder and I remembered "Oh yeah! I had once made that
entity (practicing you know!)." So i went back to my program and renamed
the component NOTGATE as NOTG. Simulated it and it executed without a
problem!
<Conclusion:
1. Read the whole error message not just the error line!
2. Always try to use unique identifiers in you program :/
Author: karim (Guest)
Posted on:
0 useful
hi I have same Error which is error loading design
there is no any problem in my code also the licen. file was downloaded
in my computer but i dont know the problem that make my modelsim doesnot
run the code is there any one has the solve thanks
Author: Lothar Miller (lkmiller) (Moderator)
Posted on:
0 useful
You seem to be very confident about that. What gives you that certitude?
>> The guy named Christian on this post pointed out to check the lines
What error messages do you get previous to the fatal error?
Author: akaryas (Guest)
Posted on:
0 useful
This do not solve my problem...
# Compile of TB_Add1b.vhd was successful.
# Compile of Add1b.vhd was successful.
# Compile of config_Add1b.vhd was successful.
# 3 compiles, 0 failed with no errors.
ModelSim > vsim -voptargs=+acc -t ns work.cfg_test
# vsim -voptargs=+acc -t ns work.cfg_test
# Error loading design
Author: Cheroot (Guest)
Posted on:
0 useful
Kel wrote:
> hi,
Posted on:
0 useful
Loding...
Author: maryam (Guest)
Posted on:
0 useful
module Alsu8bit (a,b,cin,s3,s2,s1,s0,z);
     input [7:0]a,b;
     input cin,s3,s2,s1,s0;
output [7:0]z;
wire cout;
 wire [7:0] au,lu,shr,shl;
au8bit   au0 (a[7:0],b[7:0],cin,s1,s0,cout,au[7:0]);
lu8bit   lu0(a[7:0],b[7:0],s1,s0,lu[7:0]);
shru8bit shr0 (a[7:0],1'b1,s1,s0,shr[7:0]);
shlu8bit shl0 (a[7:0],1'b1,s1,s0,shl[7:0]);
mux8bit  alsu (au[7:0],lu[7:0],shr[7:0],shl[7:0],s3,s2,z[7:0]);
endmodule
Author: mukul (Guest)
Posted on:
0 useful
hi,
i got the same error and i saved the license file in
C:\Modeltech_pe_edu_10.4a . it would be very helpful if anybody let me
know wht should i do to remove this error
Author: Sharan (Guest)
Posted on:
0 useful
Hello. This is my code of full subtractor using 2 half subtractors. No
error in compiling. but there is this error will simulating the program:
Port w and d are not found in the connection module.
module hs(diff,borrow,a,b);
  output diff,borrow;
  input a,b;
  assign diff= a^b;
  assign borrow= ~a&b;
endmodule
module fs(diff,borrow,a,b,cin);
  output diff,borrow;
  input a,b,cin;
  wire [1:0]w,d;
  hs a1(.w(w[0]),.a(a),.d(d[0]),.b(b));
  hs a2(.a(d[0]),.d(d[1]),.b(cin),.w(w[1]));
  assign diff=d[1];
  assign borrow= w[0] | w[1];
endmodule
I will be obliged if you could help.
Author: Joseph (Guest)
Posted on:
0 useful
Here's another thought....
I had this problem after moving a simulation folder containing all my
verilog and project files.  After opening the project file (*.mpf) in a
text editor, I found all verilog files were described with absolut path
names, NOT relative path names. A simple find & replace to correct the
path would fix it!
Author: Alex Cole (Guest)
Posted on:
0 useful
> path would fix it!
This is the correct fix for most of these errors. It's another one of
ModelSim's wonderful "quirks", of which there seem to be an infinite
amount!
Author: Saad (Guest)
Posted on:
0 useful
* Error: (vsim-3053) C:/Users/Uzma/Desktop/fedup/fsm_tb.v(9): Illegal
output or inout port connection for "port 'out'".
Plz help as i dont understand the meaning of this error.. output port
has been clearly identified but still its not loading the file...
Posted on:
0 useful
// My FSM TB Code
module fsm_tb;
reg clk,rst;
reg din;
reg out;
fsm MUT(din,rst,clk,.out(out));
initial
clk<=1;
always
#5 clk <=  ~(clk);
//Set occurance of sequence
initial
begin
@(posedge clk);     din <= 1'b1 ;
@(posedge clk);     din <= 1'b0 ;
end
endmodule
Author: Duke Scarring (Guest)
Posted on:
0 useful
$ vlog fsm_tb.v
Model Technology ModelSim SE-64 vlog 10.3d Compiler 2014.10 Oct  7 2014
Start time: 12:00:36 on Nov 21,2016
vlog fsm_tb.v
-- Compiling module fsm_tb
** Error: fsm_tb.v(10): near ".": syntax error, unexpected '.', expecting ')'
End time: 12:00:36 on Nov 21,2016, Elapsed time: 0:00:00
Errors: 1, Warnings: 0
After changing ".out(out)" to "my_out(out)", I got the following output:
$ vlog fsm_tb.v
Start time: 12:01:41 on Nov 21,2016
vlog fsm_tb.v
Top level modules:
        fsm_tb
End time: 12:01:41 on Nov 21,2016, Elapsed time: 0:00:00
Errors: 0, Warnings: 0
Duke
Author: Avani (Guest)
Posted on:
0 useful
It worked for me
Entering an e-mail address is optional. If you want to receive reply notifications by e-mail, please log in.
Rules — please read before posting
  • Post long source code as attachment, not in the text
  • Posting advertisements is forbidden.
Formatting options
  • [c]C code[/c]
  • [avrasm]AVR assembler code[/avrasm]
  • [vhdl]VHDL code[/vhdl]
Bild automatisch verkleinern, falls nötig
