Forum: µC & Digital Electronics STK 500 Switches
Author: Frank (Guest)
Hello,
I connected the swiches to Port C and Config PortC = Input.
The programm shall show me a binary and decimal number to detect which
switch is pressed down.
Dim deci as integer
Dim binar as byte
'configuration of the display: I did not write it down here, because the
display is working correctly.
do
upperline
lcd deci
lowerline
lcd binar
loop
If you see a mistake, I thank you for any help
Author: Peter Dannegger (peda)
Then you schould read the input port inside your loop.
> Dim deci as integer
> Dim binar as byte
I'm sure, the name of a variable has no influence, how it was displayed.
Peter
ok, but if I add "deci = portc" and "binar = portc" into the loop, the
display shows only a "0" and does not change, when I press a switch.
Author: Alexander Liebhold (lippi2000)
Hi Frank,
your problem is verry simple. If you want to write a byte value to PORTC
you have to configure the data direction (DDRC=0xFF) as output and write
data to PORT register.
But if your PORT is configured as input (DDRC=0x00)the PORT register
will enable/disable the internal pull up resistor. If you want to read
in external values you have to read pin register (PINC).
Summary:
         1. data output
               DDRC = 0xFF, write data to PORTC
         2. data input
               DDRC = 0x00, PORTC = 0x00(pull up resistors disabled),
               read data from PINC
Your loop should be: "deci = PINC" and "binar = PINC"
Greetings Alexander
webmaster@embdev.netContactAdvertising on EmbDev.net
