Forum: µC & Digital Electronics How to write a bootloader for SAM7A3?
von Al pacino D. (bigmicro)
Hello my friends,
I've a problem, I want to write my own bootloader. My first attemption
was writing an application with built in bootloader. So when I want to
upgrade for example, I flash the new firmware from RAM because my own
code will be overwritten by the new firmware.
Sometimes it works and sometime not, another problem is if upgrading a
new firmware goes wrong, the whole device must be sent back flash the uC
with a JTAG. So to solve this proble, I want a seperate bootloader e.g.
at the beginning of the flashmemory address and the application firmware
in another memorysegment of the flash.
Now I'm facing other problems, when the bootloader ends, I need to jump
to the entry-point of the application firmware. But several things need
to acount with. For example, the linker script of application firmware
needs to be modified before compiling the sources. Also, how about the
interruptvectors? Because at address zero to 1c or something the
interruptvectors is used of the bootloader, so how about the application
firmware?
Can somebody help me, give me hints or tips?
thank you very much!
P.S: Compiler = IAR EWARM 4.41A, uC = at91SAM7A3
von denilson (Guest)
Hey, what is about your sam7a3 Bootloader? Have you already solve this
problem?
von Rooney B. (rooney)
The bootloader should always be located in the flash. If the firmware
update was not successful your bootloader will be still available for a
retry. A simple bootloader will occupy about one sector.
The only functions that have to be executed in RAM are the function to
write the flash and to lock the sectors. This is done easily by
declaring the function as __ramfunc in IAR.
