Forum: µC & Digital Electronics Chan's FatFS read problem!
von Al pacino D. (bigmicro)
Hello my friends,
I'm really confused about the Chan's FatFS read-function!
I'm able to write and do loggings etc... but reading a file greater than
1 kB doesn't work! I can read up to 1 kB (not including 1 kB).
The problem is I see only 0 (zero) above 1 kB!
My buffer is 2 kB, so it's not the bufferproblem.
int main()
  FATFS Fs;
  FIL FileObject;
  char data[2048];
  const char* FileName = "0:Basic.bin";
  unsigned int ByteToRead = sizeof(data);
  unsigned int ByteRead;
  unsigned char SD = 0;
  memset(data, 0, sizeof(data));
  if( f_mount(SD, &Fs) != FR_OK )
    return 0;
  if(f_open(&FileObject, FileName, FA_OPEN_EXISTING|FA_READ) != FR_OK)
    return 0;
  FRESULT res;
  int f, e; f = e = 0;
  while(1)
    res = f_read(&FileObject, data, ByteToRead, &ByteRead);
    if(res == FR_OK)
      f++;     //just to check number of cycles
      if(ByteRead == 0) break;
      e++;
30
31
32
33
  return 0;
34
von holger (Guest)
I am missing two things in your code:
disk_initialize ()  How does it work without this ?
f_close()
I would try to read 2048 bytes in four 512 byte steps.
Only to see if f_read() has a problem reading more than
one sector.
> f_close()
> one sector.
Holger,
disk_initialize() is done when you call f_open().
f_close? hmmm I thought this was only needed when you write to SD, for
flushing the data. But maybe it also works for reading! I'll try that.
So f_read() reads only 512 bytes max.?? I thought as long as the buffer
can be filled.
Thank you.
von Andreas S. (andreas) (Admin)
f_read normally has no problems reading more than 512 bytes. But you can
easily check how much it really read by looking at ByteRead.
f_close() also didn't worked.
I managend by looping till the buffer is filled. But what if I want to
know how big the file is, so I know when to stop copying to the buffer?
von holger (Guest)
Ask FileObject.fsize ?
von Philipp B. (philipp_burch)
You should compare ByteRead against ByteToRead, not against zero.
