Forum: µC & Digital Electronics Problems with float arithmetics using a PIC 16F876
von Thomas (Guest)
Hello,
I have a very curious problem with float arithmetics:
When I use the following code
  float variable;
  variable = 12.0;
  printf ("%f", variable);
  printf (lcd_putc, "%f", variable);
the output on both the display and the RS232 is 11.9999999
This wouldn't be a problem, but in my application, I only need one
number after the comma.
So I use
  printf ("%4.1f", variable);
and the "12.0" which becomes "11.9999999" appears as "11.9"  !!!!!
Isn't there any function for outputting variables which doesn't just
"cut" the variable to the desired length like %4.1f but which rounds to
the last significant number?
So if the number is 11.99999, the program recognizes that after 11.9
there is a 9 following, so the number is rounded to 12.0.
Just like rounding in mathematics is done. Not just ignoring the numbers
after the desired range.
It's a pity that I couldn't find any rounding function within the math
functions of the ccs!
I am using a PIC16F876A and the CCS Compiler IDE version 3.43  ;  PCx
version 3.203
Thanks a lot in advance,
Thomas
: Moved by Admin
von Severino R. (severino)
If you look into the manual of CCS (i checked in version 4), you'll find
the description of printf on page 186:
f Float with truncated decimal
g Float with rounded decimal
If you use g instead of f, the number will be rounded instead of
truncated.
(I have not tried it myself)
Severino
von yalu (Guest)
That's strange. Normally all float numbers with no fractional part are
internally represented exactly. The formatting routine should not add
an error in this case.
That's a bug in the C library! The C standard requires that
  "The value is rounded to the appropriate number of digits."
You can
- ask the manufacturer of the compiler/library to fix this bug
- write your own formatting routine
- use a work-around by adding 0.05 to the value when passing it to the
  printf function:
     printf ("%4.1f", variable + 0.05);
  For negative numbers you might have to subtract 0.05 instead of
  adding it.
  You will have to remove this work-around from your software when you
  will eventually link it against a fixed library, otherwise it won't
  work correctly.
The developers of the lib haven't understood the difference between
the two format specifiers :-/
