Forum: FPGA, VHDL & Verilog modelsim simulaiton
Author: KAYHAN ÇELİK (Company: gazi) (kayooo)
hello
ı  made a fifo register with 9 bit wide and 8 bit deep
when ı make a simulation  wi or ri signal gives an error.
simulaiton says that  wi<= wi+1 or ri <=ri +1 dont be  make.
 but  my codes from the book . so there is no error in vhdl file.
but simulaiton dont work .
can any one help me please.
Author: P. K. (pek)
What does the error message say?
Author: ulf (Guest)
Hello
There is not line, where wrinc goes high. So the "elsif (wrinc='1')
never get's true.
# ** Fatal: (vsim-3421) Value 8 for ri is out of range 0 to 7.
 Time: 23 ps  Iteration: 1  Process: /fifo_tb/dut/line__61 File:
C:/Users/kayhan/modelsim/fifo.vhd
# Fatal error in Process line__61 at C:/Users/kayhan/modelsim/fifo.vhd
line 69
# HDL call sequence:
# Stopped at C:/Users/kayhan/modelsim/fifo.vhd 69 Process line__61
this is the error messege.
Author: Svenska (Guest)
A range value of 0 to 7 corresponds to three bits.
A range value of 0 to 255 corresponds to eight bits.
Author: P. K. (pek)
I assume that your Modelsim does not do an automatic wrap-around of your
limited integer.
I'd take an unsigned(2 downto 0) instead, this will be fine.
  • [vhdl]VHDL code[/vhdl]
