Forum: FPGA, VHDL & Verilog tdo pin damagement
von vr7 (Guest)
I have a problem when working with a virtex-7 xilinx fpga:
although all the connections are correct and the setup is reliable, it
fails in chaining step in the impact. it is worth to mention that I test
in the same manner by another fpga and everything is OK.
My test show an impedance of 3 Kilo Ohms between TDO pin and GND while
this quantity is about 800 Kilo Ohms in a proper fpga of the same model.
This is the only difference observed between the damaged fpga and the
proper one.
-I'd like to know if we can conclude this pin has been damaged?
- Could it be repaired anyway?
- Is there any other solution to chain and debug this fpga?
