Forum: FPGA, VHDL & Verilog HELP! Programming of DE2 Altera Board.
Author: Afkar Osman (Company: nanyang polytechnic) (afkarsosman)
Im back here asking yet another question. I'm done doing up my VHDL
codes, and when i tried to upload the codes into my DE2 Altera
Board(Cyclone II EP2C35F672C6N), it seems that it doesnt work even
though it shows "SUCCESSFUL" upon uploading using Quartus II 12.1
(64Bit). Tried using via JTAG and also Active Serial but still to no
avail. Im not too sure if it is the coding that is wrong or simply the
process of me programming the board.
If any of you can point out the mistakes I did, it would be greatly
appreciated and I'll be thankful. Im still a beginner at VHDL so it is a
little bit messy.
here are the codes, and also the attached file of what im currently
facing. The codes shown here are my Main LCD, The Controller and also
Clock Div is in the attached.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY LCD_Main IS
  PORT ( clk : IN std_logic;
      iRST_N : IN std_logic;
          SW : IN std_logic_vector(17 downto 0);
       reset : IN std_logic;
      switch : IN std_logic;
     switch2 : IN std_logic;
    LCD_DATA : OUT std_logic_vector(7 downto 0);
      LCD_RW : OUT std_logic;
      LCD_ON : OUT std_logic;
    LCD_BLON : OUT std_logic;
      LCD_RS : OUT std_logic;
      LCD_EN : OUT std_logic:='0'
END LCD_Main;
ARCHITECTURE LCDBody of LCD_Main is
  CONSTANT LCD_INITIAL:std_logic_vector(7 downto 0):="00000000";
  CONSTANT LCD_LINE1:std_logic_vector(7 downto 0):= "00000100";
  CONSTANT LCD_CH_LINE:std_logic_vector(7 downto 0):=LCD_LINE1+16;
  CONSTANT LCD_LINE2:std_logic_vector(7 downto 0):=LCD_LINE1+16+1;
  CONSTANT LUT_SIZE:std_logic_vector(7 downto 0):=(LCD_LINE2+50)+1;
  SIGNAL LUT_DATA:std_logic_vector (11 downto 0):=x"000";--In hex
--  SIGNAL count2 : integer range 0 to 65535 := 0;
  SIGNAL LUT_INDEX:std_logic_vector(7 downto 0):="00000000";
  SIGNAL mLCD_DONE:std_logic:='0';
 -- SIGNAL mLCD_ST:std_logic_vector(5 downto 0):="000000";
  SIGNAL mLCD_ST:std_logic_vector(1 downto 0):="00";
  SIGNAL mDLY:std_logic_vector(27 downto 0):=x"0000000";--In hex
  SIGNAL mLCD_Start:std_logic:='0';
  SIGNAL mLCD_DATA:std_logic_vector(7 downto 0):="00000000";
  SIGNAL mLCD_RS:std_logic:='0';
  SIGNAL sclk:std_logic:='0';
  SIGNAL startcount : integer range 0 to 1:=0;
  SIGNAL D1,D2,D3,D4,D5,D6 : std_logic_vector (11 downto 0):=x"130";
--  SIGNAL D1,D2,D3,D4,D5,D6 : std_logic_vector (11 downto 0);
  COMPONENT LCD_controller IS
       PORT( iCLK,iRS,iRST_N,istart : IN std_logic;
                              iDATA : IN std_logic_vector(7 downto 0);
                              oDone : OUT std_logic;
  END COMPONENT LCD_controller;
  COMPONENT clk_div IS
         PORT ( iCLK: IN std_logic;
                sclk: OUT std_logic
  END COMPONENT clk_div;
  BEGIN
       U0:LCD_controller
       PORT MAP(
                  iCLK => clk,
                   iRS => mLCD_RS,
                iRST_N => iRST_N,
                istart => mLCD_START,
                 iDATA => mLCD_DATA,
                 oDone => mLCD_DONE,
              LCD_DATA => LCD_DATA,
                LCD_RW => LCD_RW,
                LCD_RS => LCD_RS,
                LCD_EN => LCD_EN
        U1:clk_div
        PORT MAP( iCLK => clk,
                  sclk => sclk
    LCD_ON <= '1';
    LCD_BLON <= '1';
always : process(clk,reset,sclk)
    Begin
      IF(SW(0)='1')THEN
      D1 <= x"132";
      ELSIF(SW(1)='1')THEN
      D2 <= x"133";
      END IF;
      IF(reset = '1')THEN
          LUT_INDEX <= "00000000";
          --mLCD_ST <= "000000";
          mLCD_ST <= "00";
          --mDLY <= x"0000000";
          mLCD_DATA <= "00000000";
          mLCD_START <= '0';
          mLCD_RS <= '0';
          startcount <= 0;
          D1 <= x"130";
          D2 <= x"130";
          D3 <= x"130";
          D4 <= x"130";
          D5 <= x"130";
          D6 <= x"130";
----------LCD Line 1--------------
      ELSIF(rising_edge(clk))THEN
        startcount <= startcount + 1;
          IF (startcount = 1)THEN
            IF(LUT_INDEX < LUT_SIZE)THEN
              case mLCD_ST is
                  when "00" => mLCD_DATA <= LUT_DATA(7 downto 0);
                          mLCD_RS   <= LUT_DATA(8);
                          mLCD_START<= '1';
                          mLCD_ST   <= "01";
                  when "01" => IF(mLCD_DONE = '1') THEN
                          mLCD_START <= '0';
                          mLCD_ST    <= "10";
                         END IF;
                  when "10" => IF(switch = '1')THEN
                          IF(LUT_DATA = x"080")THEN
                            mLCD_ST <= "11";
                          END IF;
                         END IF;
                  when "11" => LUT_INDEX <= LUT_INDEX + 1;
                         mLCD_ST   <= "00";
              end case;
            ELSE
                IF(sclk = '1')THEN
                  LUT_INDEX <= LCD_INITIAL;
                END IF;
            END IF;
          END IF;
      END IF;
END PROCESS always;
----READING OF LCD COMMAND----
check:process(LUT_INDEX)
      begin
  case LUT_INDEX is
   when LCD_INITIAL+0=>LUT_DATA<=(x"030");
   when LCD_INITIAL+1=>LUT_DATA<=(x"00C");
   when LCD_INITIAL+2=>LUT_DATA<=(x"001");
   when LCD_INITIAL+3=>LUT_DATA<=(x"006");
   when LCD_INITIAL+4=>LUT_DATA<=(x"080");
   when LCD_LINE1 + 1 => LUT_DATA<=(x"130");
   when LCD_LINE1 + 2 => LUT_DATA<=(x"130");
   when LCD_LINE1 + 3 => LUT_DATA<=(x"130");
   when LCD_LINE1 + 4 => LUT_DATA<=(D6);
   when LCD_LINE1 + 5 => LUT_DATA<=(D5);
   when LCD_LINE1 + 6 => LUT_DATA<=(x"13a");
   when LCD_LINE1 + 7 => LUT_DATA<=(D4);
   when LCD_LINE1 + 8 => LUT_DATA<=(D3);
   when LCD_LINE1 + 9 => LUT_DATA<=(x"13a");
   when LCD_LINE1 + 10=> LUT_DATA<=(D2);
   when LCD_LINE1 + 11=> LUT_DATA<=(D1);
--   when LCD_LINE1 + 12=> LUT_DATA<=(x"130");
--   when LCD_LINE1 + 13=> LUT_DATA<=(x"130");
--   when LCD_LINE1 + 14=> LUT_DATA<=(x"130");
--   when LCD_LINE1 + 15=> LUT_DATA<=(x"130");
--   when LCD_LINE1 + 16=> LUT_DATA<=(x"130");
   when others => LUT_DATA <= (x"000");
   end case;
  end process check;
end LCDBody;
Author: ui (Guest)
Usually the upload process works if there is the green "successful"
message.
I don't read the code because I think you should simulate and test it
with modelsim, so the answer if it works can only be given by yourself!
Its often a good idea to start with a very generic example (just a
counter and a blinking led) to test the toolchain and see if you
- flash the right binary
- the upload process works
Author: Duke Scarring (Guest)
1 useful
Did you set the correct pins in your design?
Youtube-Video "Programming Altera FPGAs on the DE0, DE1 or DE2 (Sec 4-4D )"
Did you simulate your design?
My approach is: first simulate, 2nd synthesize
I stronly suggest: avoid ieee.std_logic_unsigned.all, use
ieee.numeric_std.all instead.
Why did you have two reset signals (iRST_N and reset)?
I attached a small testbench. The simulation stops with out-of-range
error:
# ** Fatal: (vsim-3421) Value 2 is out of range 0 to 1.
#    Time: 30 ns  Iteration: 0  Process: /lcd_main_testbench/dut/always File: LCD_Main.vhd
# Fatal error in Process always at LCD_Main.vhd line 114
Duke
Hi Duke!
thank you for taking the time to test it out for me, it is greatly
appreciated! I'll go and review again my codes and will test it out with
your testbench! Thank you again Duke!
regards,
Afkar O.
1 useful
This ist is an wrong sensitivity list, leading to a wrong simulation:
    Begin
      IF(SW(0)='1')THEN
      D1 <= x"132";
      D2 <= x"133";
      END IF;
      IF(reset = '1')THEN
          mLCD_ST <= "00";
SW is missing and sclk is not needed therein.
Your startcount prohibits any proper function of this this design. This
counter is not limited just by the definition "rango 0 to 1". You must
handle the overflow yourself.
Here this code results in the curious behaviour that startcount is
synthesized to 1 bit that toggles every clock cycle due to "startcount
<= startcount+1".
As Duke said already: you MUST run a simulation. The simulator is the
debugger of a FPGA design.
: Edited by Moderator
  • [vhdl]VHDL code[/vhdl]
