Forum: µC & Digital Electronics OPEL MID TID VDO CDR2005 WITH ARDUINO
Author: Bruno Murari (Guest)
Hi folks!
I have an VDO CDR2005 radio from my Astra G/H (here in Brazil it's
called Vectra C... by the way) and I want to communicate with this radio
using my arduino uno r3 using SCL, SDA and MRQ like you I do with my
MID/TID.
I cannot find a library or an example that shows how CDR2005
communication works because everyone wants to send data/string to
MID/TID but nobody needs to retrieve data from the radio like radio
station.
Can someone tell me how can I read data from CDR2005 using Arduino?
: Moved by Moderator
Author: Danish Belal (danishbelal)
I wouldnt assume Multi-Master Capability.
I'm a bit confused, that this Car Equipment features an I2C Bus,
though.
Author: Bruno Murari (bmurari)
> though.
Hi Danish,
I assume thats a I2C bus because this radio CDR2005 communicates to an
MID (board computer) and when I did a Web search I found many kinds of
sending data to that MID using this modified I2C (SDA, SCL, MRQ). So I
assumed that's a I2C modified type...
See the code below of the communication to send data from an Arduino to
an MID (I also attached the original code .ino, .cpp, .h to this post):
#include "TID12_10.h"
TID MyTid(7,5,6); //D5->SCL, D6->MRQ, D7->SDA
void setup() {
MyTid.space1_init(0,0); //(first position,last position) (i. e. just the
first digit)
MyTid.space2_init(1,9); //use digit 2 to 10
MyTid.clear_space(1);
MyTid.clear_space(2);
void loop() {
char first[2];
first[0] = 64; //define a symbol, here @, for more symbols see attached
picture, thanks to Georg (Gorgeous188)
first[1] = ' '; // space for blinking
first[2] = '\0'; // null character termination
MyTid.display_message(first,1,1); // (speed,position)
MyTid.display_message("This is a test...",4,2);
Do You have any idea of how can I receive data from this type of
communication (SDA, SCL, MRQ)? This radio only send data using this type
of comm and I need to read this data using an Arduino.
I already linked this radio using an Arduino UNO R3 but the Arduino
shows nothing connected to the I2C bus when I perform an address scan.
Thanks again!
Author: Uwe (Guest)
1 useful
It seems you're looking for I2C slave mode.
See examples e.g here:
https://www.arduino.cc/en/Tutorial/MasterWriter
http://dsscircuits.com/articles/arduino-i2c-slave-guide
