1 | LIBRARY IEEE;
2 | USE IEEE.STD_LOGIC_1164.ALL;
3 | USE IEEE.STD_LOGIC_UNSIGNED.ALL;
4 |
5 | ENTITY LCD_Main IS
6 | PORT ( clk : IN std_logic;
7 | iRST_N : IN std_logic;
8 | SW : IN std_logic_vector(17 downto 0);
9 | reset : IN std_logic;
10 | switch : IN std_logic;
11 | switch2 : IN std_logic;
12 |
13 | LCD_DATA : OUT std_logic_vector(7 downto 0);
14 | LCD_RW : OUT std_logic;
15 | LCD_ON : OUT std_logic;
16 | LCD_BLON : OUT std_logic;
17 | LCD_RS : OUT std_logic;
18 | LCD_EN : OUT std_logic:='0'
19 | );
20 | END LCD_Main;
21 |
22 | ARCHITECTURE LCDBody of LCD_Main is
23 |
24 | CONSTANT LCD_INITIAL:std_logic_vector(7 downto 0):="00000000";
25 | CONSTANT LCD_LINE1:std_logic_vector(7 downto 0):= "00000100";
26 | CONSTANT LCD_CH_LINE:std_logic_vector(7 downto 0):=LCD_LINE1+16;
27 | CONSTANT LCD_LINE2:std_logic_vector(7 downto 0):=LCD_LINE1+16+1;
28 | CONSTANT LUT_SIZE:std_logic_vector(7 downto 0):=(LCD_LINE2+50)+1;
29 |
30 | SIGNAL LUT_DATA:std_logic_vector (11 downto 0):=x"000";--In hex
31 | -- SIGNAL count2 : integer range 0 to 65535 := 0;
32 | SIGNAL LUT_INDEX:std_logic_vector(7 downto 0):="00000000";
33 | SIGNAL mLCD_DONE:std_logic:='0';
34 | -- SIGNAL mLCD_ST:std_logic_vector(5 downto 0):="000000";
35 | SIGNAL mLCD_ST:std_logic_vector(1 downto 0):="00";
36 | SIGNAL mDLY:std_logic_vector(27 downto 0):=x"0000000";--In hex
37 | SIGNAL mLCD_Start:std_logic:='0';
38 | SIGNAL mLCD_DATA:std_logic_vector(7 downto 0):="00000000";
39 | SIGNAL mLCD_RS:std_logic:='0';
40 | SIGNAL sclk:std_logic:='0';
41 | SIGNAL startcount : integer range 0 to 1:=0;
42 | SIGNAL D1,D2,D3,D4,D5,D6 : std_logic_vector (11 downto 0):=x"130";
43 |
44 | COMPONENT LCD_controller IS
45 | PORT( iCLK,iRS,iRST_N,istart : IN std_logic;
46 | iDATA : IN std_logic_vector(7 downto 0);
47 | oDone : OUT std_logic;
48 | LCD_DATA : OUT std_logic_vector(7 downto 0);
49 | LCD_RW : OUT std_logic;
50 | LCD_RS : OUT std_logic;
51 | LCD_EN : OUT std_logic
52 | );
53 | END COMPONENT LCD_controller;
54 |
55 | COMPONENT clk_div IS
56 | PORT ( iCLK: IN std_logic;
57 | sclk: OUT std_logic
58 | );
59 | END COMPONENT clk_div;
60 |
61 | BEGIN
62 | U0:LCD_controller
63 | PORT MAP(
64 | iCLK => clk,
65 | iRS => mLCD_RS,
66 | iRST_N => iRST_N,
67 | istart => mLCD_START,
68 | iDATA => mLCD_DATA,
69 | oDone => mLCD_DONE,
70 | LCD_DATA => LCD_DATA,
71 | LCD_RW => LCD_RW,
72 | LCD_RS => LCD_RS,
73 | LCD_EN => LCD_EN
74 | );
75 |
76 | U1:clk_div
77 | PORT MAP( iCLK => clk,
78 | sclk => sclk
79 | );
80 |
81 | LCD_ON <= '1';
82 | LCD_BLON <= '1';
83 |
84 | always : process(clk)
85 | Begin
86 |
87 | IF(switch2 = '1' AND switch2'event) THEN
88 | startcount <= startcount + 1;
89 | END IF;
90 |
91 | IF(startcount = 1) THEN
92 | If(sclk = '1' and sclk'event)THEN
93 |
94 | ----------LCD Line 1--------------
95 |
96 | IF(reset = '0')THEN
97 | LUT_INDEX <= "00000000";
98 | --mLCD_ST <= "000000";
99 | mLCD_ST <= "00";
100 | --mDLY <= x"0000000";
101 | mLCD_DATA <= "00000000";
102 | mLCD_START <= '0';
103 | mLCD_RS <= '0';
104 |
105 | startcount <= 0;
106 | D1 <= x"130";
107 | D2 <= x"130";
108 | D3 <= x"130";
109 | D4 <= x"130";
110 | D5 <= x"130";
111 | D6 <= x"130";
112 |
113 | ELSIF(rising_edge(clk))THEN
114 | IF(LUT_INDEX < LUT_SIZE)THEN
115 | case mLCD_ST is
116 | when "00" => mLCD_DATA <= LUT_DATA(7 downto 0);
117 | mLCD_RS <= LUT_DATA(8);
118 | mLCD_START<= '1';
119 | mLCD_ST <= "01";
120 |
121 | when "01" => IF(mLCD_DONE = '1') THEN
122 | mLCD_START <= '0';
123 | mLCD_ST <= "10";
124 | END IF;
125 |
126 | when "10" => IF(switch = '1')THEN
127 | IF(LUT_DATA = x"080")THEN
128 | mLCD_ST <= "11";
129 | END IF;
130 | END IF;
131 |
132 | when "11" => LUT_INDEX <= LUT_INDEX + 1;
133 | mLCD_ST <= "00";
134 | end case;
135 | ELSE
136 | IF(sclk = '1')THEN
137 | LUT_INDEX <= LCD_INITIAL;
138 | END IF;
139 | END IF;
140 | END IF;
141 | END IF;
142 | END IF;
143 | END PROCESS always;
144 |
145 |
146 |
147 | ----READING OF LCD COMMAND----
148 | check:process(LUT_INDEX)
149 | begin
150 |
151 | case LUT_INDEX is
152 | when LCD_INITIAL+0=>LUT_DATA<=(x"030");
153 | when LCD_INITIAL+1=>LUT_DATA<=(x"00C");
154 | -- when LCD_INITIAL+2=>LUT_DATA<=(x"001");
155 | when LCD_INITIAL+2=>LUT_DATA<=(x"006");
156 | when LCD_INITIAL+3=>LUT_DATA<=(x"080");
157 |
158 |
159 |
160 |
161 | when LCD_LINE1 + 1 => LUT_DATA<=(x"130");
162 | when LCD_LINE1 + 2 => LUT_DATA<=(x"130");
163 | when LCD_LINE1 + 3 => LUT_DATA<=(x"130");
164 | when LCD_LINE1 + 4 => LUT_DATA<=(D6);
165 | when LCD_LINE1 + 5 => LUT_DATA<=(D5);
166 | when LCD_LINE1 + 6 => LUT_DATA<=(x"13a");
167 | when LCD_LINE1 + 7 => LUT_DATA<=(D4);
168 | when LCD_LINE1 + 8 => LUT_DATA<=(D3);
169 | when LCD_LINE1 + 9 => LUT_DATA<=(x"13a");
170 | when LCD_LINE1 + 10=> LUT_DATA<=(D2);
171 | when LCD_LINE1 + 11=> LUT_DATA<=(D1);
172 | -- when LCD_LINE1 + 12=> LUT_DATA<=(x"130");
173 | -- when LCD_LINE1 + 13=> LUT_DATA<=(x"130");
174 | -- when LCD_LINE1 + 14=> LUT_DATA<=(x"130");
175 | -- when LCD_LINE1 + 15=> LUT_DATA<=(x"130");
176 | -- when LCD_LINE1 + 16=> LUT_DATA<=(x"130");
177 | when others => LUT_DATA <= (x"000");
178 |
179 | end case;
180 |
181 | end process check;
182 | end LCDBody;
