Forum: FPGA, VHDL & Verilog FPGA Nexys 2 Spartan 3E Timer with buzzer
von Katja (Guest)
Hi!
I am trying to create a timer that counts down from 6 to 0 and then
activates a buzzer. I am using the 50MHz clock on the board and divide
the frequency to 1/60 Hz so that the counter (connected to the 7seg
display) counts down in minutes. This part works.
I am also dividing the 50MHz clock on the board to get a frequency to
send to the buzzer, but the buzzer will not activate. I am using the L15
pin and GND on the board for the buzzer. I have tried a range of
400-4000 Hz.
Any ideas as to why the buzzer won't activate? The buzzer is working
since I tried connecting it to a 3.3V pin and it activated.
Maybe there's a problem inside the unknown code.
Katja wrote:
> The buzzer is working since I tried connecting it to a 3.3V pin and it
> activated.
Does "activated" mean "beeped"?
So maybe it is an active buzzer that simply needs a supply and not a
AC- or pulse-signal.
> activated.
How much current needs this buzzer? More than a FPGA pin is able to
source?
But first question is: is the simulation ok and running fine?
What? You didn't simulate?
Well, know: the simulator is the debugger in a hardware design. And your
kind of design is easily simulated as most of the stimulus is a clock
with 50MHz...
: Edited by Moderator
von AmorLogic (Guest)
Please post VHDL, testbench and electronic schematic.
