Forum: FPGA, VHDL & Verilog A FPGA Programer
von Abolfazl M. (Company: posedge.ir) (firetooth)
Posedge FPGA Group design a new tiny FPGA programmer than support ISE
and Vivado [SDk, Impact and chipscope] fully. the Posedge programmer
size is 4x3 Cm.
features:
- high Speed (30Mbps)
- USB interface
- full support ISE and Vivado
- Micro USB connector
Chips support:
- Xilinx's FPGAs [SPARTAN، VIRTEX, ARTIX, KINTEX]
- Xilinx Zynq-7000
- Xilinx CoolRunner™/CoolRunner-II CPLDs
- Xilinx Platform Flash ISP configuration PROMs
- SPI PROM
- BPI PROM
price is 20$ only
for more info please visit this link:
http://posedge.ir/product/%D9%BE%D8%B1%D9%88%DA%AF%D8%B1%D8%A7%D9%85%D8%B1-fpga-posedge-jtag-hs2/
: Locked by Moderator
von -gb- (Guest)
Website seems broken, Error 403.
von Chriss (Guest)
Ganz schön mutig da drauf zu klicken... :-)
von -gb- (Guest)
Ich klicke auf alles was nicht bei 3 aufm Baum ist. Nur diese komischen
Schriftzeichen am Ende der URL konnte man nicht von rechts nach links
löschen. Aber auch http://posedge.ir ist kaputt. Ein Vorbote vom Brexit?
The problem will be solved soon
von JB (Guest)
Browser in einer VM benutzen?
von Antti L. (trioflex)
the license fee for the FTDI cost 10$ (payable to Digilent Inc), if you
are legal business how can you sell the product for 20$ ?
You must have very low margin then, really low!
von BSDL File (Guest)
i am programming XCF02S which is part of a Jtag chain that includes 3
devices (only 1 should be programmed)
I could program the device by ignoring the TDO.
when I open the XCF02S.bsdl with the Boundary scan tool i receive an
error
09:29:06 - Exception: '' is not a valid integer value
do I need a special format or what should I do to program the device
correctly (including the TDO)
First of all: start a NEW thread for a NEW question.
And when starting a new thread, read your description as if you don't
know anything about your problem. Check whether you gave enough
information to help. If not: add it.
What programming tool?
What programming toolchain?
What tool?
Who says that?
What means "could" in this context?
CAN you or WOULD you like to?
This topic is locked and can not be replied to.
