Forum: FPGA, VHDL & Verilog USB Data Treatment VHDL
von Alex G. (alexgainza)
To utilize the USB port in a FPGA board via VHDL code, what are the
.vhds/code that I need?  I suppose there is some type of
template/pre-written code for treating output and input data; honestly,
I can't imagine there is not one, writting the entire code each time
must be tedious.
Can somebody pass them to me¿?
von Gustl B. (-gb-)
Which FPGA Board? Is the USB really connected to FPGA IOs or to another
IC?
: Edited by User
It is a Basys 3. It is connected to the FPGA's USB port.  I would like
to know how I should configure the .vhds to enable input and output of
data.
: Edited by User
von Gustl B. (-gb-)
No.
The Micro USB is connected to the FTDI FT2232HQ which acts as JTAG and
UART.
The UAB-A Port is connected to the PIC24F Mikrocontroller.
http://store.digilentinc.com/basys-3-artix-7-fpga-trainer-board-recommended-for-introductory-users/
There are Datasheet and Schematic.
Gustl B. wrote:
> The Micro USB
I'm trying to use the actual USB port on the board, not the micro USB,
to send data to a transmitter that is connected to the board by an USB
to DB9 cable.
What do I need to configure for doing that?
PD: Sorry if I'm being stubborn but it is the first time I'm trying to
input/output data from the board.
von -gb- (Guest)
For this task, I would use the micro-USB because it is an UART. This is
very simple to move Data. The Big USB-A Port is connected to an
Microcontroller, not to the FPGA. I am not sure if you can use this Port
for arbitrary USB Devices. This Port is i think for just Mouse/Keyboard
and the Microcontroller also handles the SD-Card im the Basys has an
SD-Card-Slot. Oh and ... if you put an USB-Stick in this Port FAT32
formatted with an FPGA Bitstream at its root, then you can configure the
FPGA from there (boot the FPGA).
For moving Data you should use the micro-USB. It can go up to 12 MBaud.
