Forum: FPGA, VHDL & Verilog How to perform division of two Q15 values in Verilog , with out using '/' (division) Operator?
von Mog4kor K. (Company: student) (mohankotgire) Flattr this
Hello,
As division operation (/) is expensive in case of FPGA ? Is it possible
to perform division of two Q15 format numbers with basic shift
operations?
Could someone help me by providing some example?
Thanks in advance!
von Charles G. (Company: Ingenieurbuero Gardiner) (cfgardiner)
The solution is outlined in most standard text-books on logic design. In
"Computer Organisation and Design" from Patterson and Hennessy it's
around page 260 (2nd Edition).
It's not that difficult really. My solution derived from the description
in the text runs to 120 lines of VHDL code, including empty lines, two
processes and a function to make things more readable.
Now that's something for free, isn't it ;) And I'd never forgive myself
for just throwing code at you providing a solution you don't understand
Yes, it is. It results in a big and slow combinatorial divider. Simply
try it. And have a look for the RTL schematics.
> Is it possible  to perform division of two Q15 format numbers
> with basic shift  operations?
Yes.
And it's fairly simple...
Hello Mr.Charles Gardiner ,
Thanks for the reference , I found a detailed explanation in the
mentioned book. Now i need to implement the same in Verilog to divide
two numbers (X[15], Y[15]) . If you already have some Verilog code
,which performs division operation of any two binary numbers with shift
operation . Could you share it with me (only if you already have)? I
dont have any problem if the code doesn't have comments ;). It will
reduce my effort a lot :)
Not meaning to hurt your feelings, but you're beginning to sound a bit
like my granddaughter when she doesn't want to do things herself even
though she often could. She has the same perseverance as well ...
Sorry, I don't do Verilog unless you pay me. It feels like trying to
carve a statue with a screwdriver. I need compensation for that.
SystemVerilog is a different matter.
Back to the point, if you really want code you don't understand, I can
certainly help you there. The attachment is the obfuscated solution for
unsigned 32-bit dividend/divisor in VHDL, but it's not as useless for
your task as it might seem at first. For a 16-bit solution, you probably
just have to change the vector widths from 6 downto 0 to 5 downto 0
You could
1) write a Verilog wrapper around it and instantiate that in a mixed
language environment
2) synthesise it and work out the code from the logic generated. Maybe
you're a guy who understands schematics better than text books.
3) With some FPGA tools you can even write out a verilog netlist, which
will give you what you want, just hope your tutor will accept it.
If your synthesis tool is complaining about unconstrained ports, just
set the vectors on the top-level divider_uu to (31 downto 0) or (15
downto 0)
No you didn't hurt me, as of course I could do it by myself with the
help of reference you provided , But tried to escape from that even( MY
Bad :( ).
 .Hahaha..may be you are right I started sounding like your grand
daughter.
May be I could have paid for that , but i wont learn verilog if I do so
.Nervelessness , the code you provided is perfect. It helped me a bit to
correct my implemented code. Thanks for that :). I could see 11 people
already downloaded your code(many like me trying to  escape from putting
effort ;) )
