Forum: FPGA, VHDL & Verilog biphasic waveform
von Bose C. (Company: RD) (bosechandran)
Dear all im new here try to learning  verilog and vhdl. i need to
generate biphasic waveform width of the pulse 12.5 ns.
 for +ve 12.5 ns  and -ve 12.5 ns
for the second channel vary the width of pulse i should change and delay
b/w first and second channel o/p is 10ns.
im  using spartan 3e kit and ise design suite 14.7
Thank you all
von Tim (Guest)
Good Luck.
I am missing the question.
von bose (Guest)
I want program to generate biphasic waveform. I'm unable to generate
negative pulse. Biphasis is +1,-1 right
von FPGA-Expert (Guest)
Since you are not even able to define precisely what you have, need and
where is your misunderstanding, you should think of leraing something
different than electronics.
Estimating you want to generate a symmetric voltage with the S3E eval
kit, using the DACs (what you have not mentioned yet) I shall conclude,
that you either need to add som offset to the DACs output value or need
a bias loaded PWM driving the pins in oder to add offset eletronically.
AFAIK there is no negative voltage with the DACs of the S3E, so some
additional cicuitry is required.
But hostly: WE did not have internet and not even usenet to learn about
that all, and I more and more wonder how it is possible that there are
engineers around who have done such things before, whithout the
possibility to access knowledge already present(ed some where).
ok i try to learn it due to dead end i asked that above question. thanks
