Forum: FPGA, VHDL & Verilog Search for automotive FPGA or CPLD for OSD
von J. Hebeler (Guest)
Hello,
for an automotive application I have to implement an OSD for a PAL video
signal. In theory this is not complicated, with a LM1881 I get the sync
information, in a large enough memory there is the information if a
pixel should show black, white or the original signal, which is read and
put into a multiplexer, such that the correct signal is selected.
But as I am lacking experience in this field I find it rather
complicated to find a suitable device. I would prefer something with
legs(TQFP) rather than BGA, beeing cost effective is a huge plus.
Looking at the filtered result at farnell or digikey I can't really
decide, which part is suited for such a task. Can I implement the memory
interface and the controll logic on a simple CPLD, do I need an FPGA?
Can I also add an UART/I2C interface?
If you could point me in the right direction this would be great.
P.S: I know that there are chips like the MAX7456, but as most of them
are discontinued, I prefer not to implement them in a new design.
J. Hebeler wrote:
> I would prefer something with legs(TQFP) rather than BGA, beeing cost
Why do you expect a BGA to be more expensive then a "wired" package?
> Can I implement the memory interface and the controll logic on a simple
> CPLD
Maybe, but if you want to
then a CPLD will get to the limits very soon. So the result is:
> do I need an FPGA?
Yes.
Start with an EVAL board that has your desired type of memory and a big
FPGA on it. Then get your design running. Afterwards you can choose a
FPGA that fits the application.
: Edited by Moderator
von Joe F. (easylife)
MinimOSD in combination with an automotive ATmega might be an option
too.
von derguteweka (Guest)
Moin,
Well, also in theory it'll be nice, if you have some pixelclock phase
locked at least to h-sync, which means additional hardware/PLL.
Also PAL is interlaced. Interlaced video with an overlay in pure black
or white will flicker like crazy.
cheers,
WK
Wrong wording. I do not expect the BGA to be more expensive. I want a
wired package as it simplifies the design and manufacturing for the
application.
>> do I need an FPGA?
>Yes.
ok, good to know
This is where I see myself at the start again. I can of course buy a
ZYNQ, Virtex or Stratix 10 FPGA board and I will definitly have enough
power, memory and peripherals, but it seems to me that this won't help
me choose the right automotive grade(temperature range) FPGA that allows
me to implement my functionallity, without having to put a >500 pin
device on my board
> too.
The minimOSD still uses the MAX7456, which is a discontinued chip.
Further the quality of the used IC on the minimOSD seem to vary a lot,
so I don't want to use them in a product I have to support for 10 - 15
years.
Similar systems are already in use and work flicker free.
von Strubi (Guest)
I assume you want to use an FPGA in order to avoid the extra hassle/cost
with buffering the video (external RAM).
However when coming to Automotive, you might be better off with a signal
processor, such as BF561 or BF549 from Analog Devices, the latter being
specifically designed for the vertical markets with long term
availability and all the automotive extras (MOST, CAN).
The only storage you need is the bitmap for the OSD elements, this is
then likely to reside in a parallel flash. If the bitmap depth is like
1-2 bits per pixel or if RLE compression is an option, bandwidth of a
SPI flash will suffice, too.
I'm in no way affil-(nospam)-iated with ADI, but have made good
experiences with this chip family for PAL processing (a few years ago).
If you still want to go with the FPGA, you might be better off with a
functional simulation and nail down memory reqs before you decide for a
specific chip.
von Strubi (Guest)
Addendum: Spartan-6 LX9 are available in TQFP. Not sure if this one has
enough memory for your app, but you can definitely do fancy hacks there
with character ROM in SPI flash and stream it at the 27 MHz pixclk.
