Forum: FPGA, VHDL & Verilog Modelsim simulation OK but FPGA implementation incorrect!!
von Omar (Guest)
I am designing a divide by 4/ divide by 8 module. Modelsim simulation
runs as expected. However upon programming with Altera I get a funky
output on d_out but clk_out is running as expected.
I have attached the project file which includes everything.
von dude (Guest)
I dont like to open .rar. maybe single files ok?
That's a few lines of code. Why do you post them in a rar?
von Omar R. (ojay77)
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity decimator2 is
  port (clk, sync, d_in: IN std_logic;
        clk_out, d_out: OUT std_logic);
end decimator2;
architecture FSM of decimator2 is
type state is (s0, s1, s2, s3, s4, s51, s61, s71, s81, s5, s6, s7, s8, s9, s10, s11, s12, s13, s14, s15, s16);
signal c_state: state := s0;
signal temp: std_logic;
begin
d_out <= temp;
process (clk)
begin
if (clk = '1' and clk'event) then
  case c_state is
    when s0 => if (sync = '1') then
        c_state <= s1;
         else
        c_state <= s0;
         end if;
    when s1 => if (sync = '1') then
        c_state <= s2;
30
         else
31
        c_state <= s0;
32
         end if;
33
    when s2 => if (sync = '1') then
34
        c_state <= s3;
35
         else
36
        c_state <= s0;
37
         end if;
38
    when s3 => if (sync = '1') then
39
        c_state <= s4;
40
         else
41
        c_state <= s0;
42
         end if;
43
    when s4 => if (sync = '1') then
44
        c_state <= s5;
45
         else
46
        c_state <= s51;
47
         end if;
48
    when s51 => if (sync = '1') then
49
        c_state <= s1;
50
          else
51
        c_state <= s61;
52
          end if;
53
    when s61 => if (sync = '1') then
54
        c_state <= s1;
55
          else
56
        c_state <= s71;
57
          end if;
58
    when s71 => if (sync = '1') then
59
        c_state <= s1;
60
          else
61
        c_state <= s81;
62
          end if;
63
    when s81 => if (sync = '1') then
64
        c_state <= s1;
65
          else
66
        c_state <= s51;
67
          end if;
68
    when s5 => if (sync = '1') then
69
        c_state <= s6;
70
         else
71
        c_state <= s0;
72
         end if;
73
    when s6 => if (sync = '1') then
74
        c_state <= s7;
75
         else
76
        c_state <= s0;
77
         end if;
78
    when s7 => if (sync = '1') then
79
        c_state <= s8;
80
         else
81
        c_state <= s0;
82
         end if;
83
    when s8 => if (sync = '0') then
84
        c_state <= s9;
85
         else
86
        c_state <= s1;
87
         end if;
88
    when s9 => if (sync = '0') then
89
        c_state <= s10;
90
         else
91
        c_state <= s1;
92
         end if;
93
    when s10 => if (sync = '0') then
94
        c_state <= s11;
95
         else
96
        c_state <= s1;
97
         end if;
98
    when s11 => if (sync = '0') then
99
        c_state <= s12;
100
         else
101
        c_state <= s1;
102
         end if;
103
    when s12 => if (sync = '0') then
104
        c_state <= s13;
105
         else
106
        c_state <= s1;
107
         end if;
108
    when s13 => if (sync = '0') then
109
        c_state <= s14;
110
         else
111
        c_state <= s1;
112
         end if;
113
    when s14 => if (sync = '0') then
114
        c_state <= s15;
115
         else
116
        c_state <= s1;
117
         end if;
118
    when s15 => if (sync = '0') then
119
        c_state <= s16;
120
         else
121
        c_state <= s1;
122
         end if;
123
    when s16 => if (sync = '0') then
124
        c_state <= s9;
125
         else
126
        c_state <= s1;
127
         end if;
128
    when others => c_state <= s0;
129
  end case;
130
end if;
131
end process;
132
133
process (c_state)
134
begin
135
case c_state is
136
  when s0 => temp <= '0'; clk_out <= '0';
137
  when s1 => temp <= '0'; clk_out <= '0';
138
  when s2 => temp <= '0'; clk_out <= '0';
139
  when s3 => temp <= '0'; clk_out <= '0';
140
  when s4 => temp <= '0'; clk_out <= '0';
141
  when s51 => temp <= d_in; clk_out <= '0';
142
  when s61 => temp <= temp; clk_out <= '1';
143
  when s71 => temp <= temp; clk_out <= '1';
144
  when s81 => temp <= temp; clk_out <= '0';
145
  when s5 => temp <= '0'; clk_out <= '0';
146
  when s6 => temp <= '0'; clk_out <= '0';
147
  when s7 => temp <= '0'; clk_out <= '0';
148
  when s8 => temp <= '0'; clk_out <= '0';
149
  when s9 => temp <= d_in; clk_out <= '0';    --beginning of decimate by 8
150
  when s10 => temp <= temp; clk_out <= '0';
151
  when s11 => temp <= temp; clk_out <= '1';
152
  when s12 => temp <= temp; clk_out <= '1';
153
  when s13 => temp <= temp; clk_out <= '1';
154
  when s14 => temp <= temp; clk_out <= '1';
155
  when s15 => temp <= temp; clk_out <= '0';
156
  when s16 => temp <= temp; clk_out <= '0';
157
end case;
158
end process;
159
end FSM;
I added a .rar file because I wanted to present all the project files,
not just the source code.
von Omar (Guest)
Bump!
Omar R. wrote:
> the source code.
What's the intention of that code? What should it do? And what does it
do instead?
You must read about asynchronous inputs and about synchronizing inputs.
To keep things short: never ever use a async input in a FSM.
The intention is for it to divide the input data and input clock (d_iun,
clk) by 4 or by 8 based on the length of the sync signal (if it is 4
cycles long then divide by 4, if 8 then divide by 8).
d_out should be basically a sampled and held d_in (held for 4 or 8
cycles). Currently it is not being held correctly. However, clk_out is
correct.
von daniel__m (Guest)
Omar R. wrote:
> process (c_state)
rethink the sensitivity list of your second process. the simulation my
be wrong.
Indeed the synthesizer should report something about an incomplete
sensitivity list...
