Forum: FPGA, VHDL & Verilog Multiple Driver Nets _segmento{OBUF[0]
von ricardo (Guest)
Help me .... I do not know where this error is.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity colculadora_4bits is
Port(chaves_a, chaves_b: in std_logic_vector(3 downto 0);
         led: inout bit;
        led_1: inout bit;
        segmento: out bit_VECTOR(0 TO 6);
        chave_sinal: inout std_logic;
        clk: in std_logic;
        display: out bit_VECTOR(7 DOWNTO 0);
         x: inout integer;
        subtracao, soma: inout integer);
end colculadora_4bits;
architecture Behavioral of colculadora_4bits is
begin
process(chaves_a, chaves_b, chave_sinal)
begin
    if (chave_sinal = '0') then
        subtracao <= 0;
        soma <= conv_integer(chaves_a) + conv_integer(chaves_b);
    elsif(chave_sinal = '1') then
30
        soma <= 0;
31
        subtracao <= conv_integer(chaves_a) - conv_integer(chaves_b);
32
    END IF;
33
end process;
34
35
36
PROCESS(subtracao)
37
begin
38
        if (subtracao < 0) then
39
            led_1 <= '1';
40
            led <= '0';
41
        elsif(subtracao >= 0) then
42
            led <= '1';
43
            led_1 <= '0';
44
        end
45
    if;
46
end process;
47
48
49
PROCESS(x, soma, subtracao, chave_sinal, clk)
50
BEGIN
51
52
        if (subtracao <= 0) then
53
            x <= subtracao + (subtracao * (-2));
54
         else
55
          x<= subtracao;
56
        end if;
57
58
        if (chave_sinal = '1') then
59
            if (x = 0) then
60
                if (clk 'event and clk='1') then
61
62
                    display <="11111110";
63
                   segmento <= "0000001";
64
                end if;
65
             if (clk'event and clk = '0') then
66
                display <= "11111101";
67
68
            end if;
69
70
            elsif(x = 1) then
71
            if (clk 'event and clk = '1') then
72
73
74
                segmento <= "1001111";
75
           end if;
76
77
78
79
        end if;
80
81
        elsif(x = 2) then
82
83
84
            segmento <= "0010010";
85
            end if;
86
87
88
89
            end if;
90
91
        elsif(x = 3) then
92
93
94
        segmento <= "0000110";
95
        end if;
96
97
98
99
        end if;
100
101
        elsif(x = 4) then
102
103
104
        segmento <= "1001100";
105
        end if;
106
107
108
109
            end if;
110
111
112
        elsif(x = 5) then
113
114
115
        segmento <= "0100100";
116
        end if;
117
118
119
120
        end if;
121
122
        elsif(x = 6) then
123
124
125
        segmento <= "0100000";
126
        end if;
127
128
129
130
        end if;
131
132
        elsif(x = 7) then
133
134
135
        segmento <= "0001111";
136
        end if;
137
        if (clk'        event and clk = '0') then
138
139
140
        end if;
141
142
        elsif(x = 8) then
143
144
145
        segmento <= "1111111";
146
        end if;
147
148
149
150
        end if;
151
152
        elsif(x = 9) then
153
154
155
        segmento <= "0000100";
156
        end if;
157
158
159
160
        end if;
161
162
        elsif(x = 10) then
163
164
165
166
        end if;
167
168
169
170
        end if;
171
172
        elsif(x = 11) then
173
174
175
176
        end if;
177
178
179
180
        end if;
181
182
        elsif(x = 12) then
183
184
185
186
        end if;
187
188
189
190
        end if;
191
192
        elsif(x = 13) then
193
194
195
196
        end if;
197
198
199
200
        end if;
201
202
        elsif(x = 14) then
203
204
205
206
        end if;
207
208
209
210
        end if;
211
212
        elsif(x = 15) then
213
214
215
216
        end if;
217
218
219
220
        end if;
221
  end if;
222
end if;
223
224
225
226
227
    if (soma = 0) then
228
        if (clk'event and clk='1') then
229
230
231
        end if;
232
233
        display <= "11111101" after 5ns;
234
        segmento <= "0000001" after 5ns;
235
        end if;
236
237
        elsif(soma = 1) then
238
239
240
241
        end if;
242
243
244
245
        end if;
246
247
        elsif(soma = 2) then
248
249
250
251
        end if;
252
253
254
255
        end if;
256
257
        elsif(soma = 3) then
258
259
260
261
        end if;
262
263
264
265
        end if;
266
267
        elsif(soma = 4) then
268
269
270
271
        end if;
272
273
274
275
        end if;
276
277
        elsif(soma = 5) then
278
279
280
281
        end if;
282
283
284
285
        end if;
286
287
        elsif(soma = 6) then
288
289
290
291
        end if;
292
293
294
295
        end if;
296
297
        elsif(soma = 7) then
298
299
300
301
        end if;
302
303
304
305
        end if;
306
307
        elsif(soma = 8) then
308
309
310
311
        end if;
312
313
314
315
        end if;
316
317
        elsif(soma = 9) then
318
319
320
321
        end if;
322
323
324
325
        end if;
326
327
        elsif(soma = 10) then
328
329
330
331
        end if;
332
333
334
335
        end if;
336
337
        elsif(soma = 11) then
338
339
340
341
        end if;
342
343
344
345
        end if;
346
347
        elsif(soma = 12) then
348
349
350
351
        end if;
352
353
354
355
        end if;
356
357
        elsif(soma = 13) then
358
359
360
361
        end if;
362
363
364
365
         end if;
366
367
        elsif(soma = 14) then
368
369
370
371
        end if;
372
373
374
375
        end if;
376
377
        elsif(soma = 15) then
378
379
380
381
        end if;
382
383
384
385
        end if;
386
387
        elsif(soma = 16) then
388
389
390
391
        end if;
392
393
394
395
        end if;
396
397
        elsif(soma = 17) then
398
399
400
401
        end if;
402
403
404
405
        end if;
406
407
        elsif(soma = 18) then
408
409
410
411
        end if;
412
413
414
415
        end if;
416
417
        elsif(soma = 19) then
418
419
420
421
        end if;
422
423
424
425
        end if;
426
427
        elsif(soma = 20) then
428
429
430
431
        end if;
432
433
434
435
        end if;
436
437
        elsif(soma = 21) then
438
439
440
441
        end if;
442
443
444
445
        end if;
446
447
        elsif(soma = 22) then
448
449
450
451
        end if;
452
453
454
455
        end if;
456
457
        elsif(soma = 23) then
458
459
460
461
        end if;
462
463
464
465
        end if;
466
467
        elsif(soma = 24) then
468
469
470
471
        end if;
472
473
474
475
        end if;
476
477
        elsif(soma = 25) then
478
479
480
481
        end if;
482
483
484
485
        end if;
486
487
        elsif(soma = 26) then
488
489
490
491
        end if;
492
        if (clk'event and clk='0') then
493
        display <="11111101";
494
495
        end if;
496
497
        elsif (soma = 27) then
498
        if (clk'event and clk = '1') then
499
        display <= "11111110";
500
501
        end if;
502
503
504
505
        end if;
506
507
        elsif (soma = 28) then
508
509
510
511
        end if;
512
513
514
515
        end if;
516
517
        elsif (soma = 29) then
518
519
520
521
        end if;
522
523
524
525
        end if;
526
527
        elsif (soma = 30) then
528
529
530
531
        end if;
532
533
534
535
        end if;
536
537
538
end if;
539
  end if;
540
end process;
541
end Behavioral;
: Edited by Moderator
von Klakx (Guest)
normally this error occurs if you drive "segmento" from more than one
process. But I think you have a real bigger problem with your clock
description.
 shows one problem. There should be a single asynchronous reset like
PROCESS(a_reset_n,clk)
 or only synchronous reset and signals. Then your sensitivity list is
very clear:
PROCESS(clk)
The 2nd pitfall in coding metholodgy is the multiple use of the
rising_edge(clk) (or clk'event ..). Your process should only have one
use of this like
[vhdl]
process(clk)
begin
   if rising_edge(clk) then
            if (x = 0) then
                end if;
            end if; -- <-- this was also missing?
            else
            end if;
   end if;
of course you have take a 2nd look of your cycle timing after rework
end process;
The error itself is that you have multiple clocks in one megamonster
process. Where did you learn this crude design mixed muddled practice?
It must be your own idea, because I never saw anything roughly similar
like that..
OK, having cleared that, one question: did you ever do a smaller design
like a flashing LED or a chasing light?
Never ever use the numeric_std together with the std_logic_arith libs.
You will encounter some very weird error messages...
What do you try with that curious piece of code?
Is it some kind of counter on a 7 segment display?
von ricardo (Guest)
I have to do sum and subtraction operations using 8 keys, for each 4bit
binary number and the result appears on the decimal display. The LED
indicates whether the result is negative or not
von ricardo (Guest)
Sorry if my code is extensive but I'm new to vhdl and I do not have much
idea how to do it
Thank you for your help
>          led: inout bit;
>         led_1: inout bit;
>         clk: in std_logic;
>          x: inout integer;
So, for that exercise for sure you will not need that much ports (BTW:
using inout ports just for laziness eg. "easy way to read an output
port" is a reason for being fired...). Simply 2x4 inputs for the
switches, 7 outputs for the seven segment display, one output for the
sign led, and one input for the operation (add/subtract). Am I missing
one?
I don't think so.
You will need no clock because the whole design is completely
combinatorial.
All in all it could be implemented in a lookup table with 9 inputs and 8
outputs. So the implementation in a 512x8 RAM would be the most
efficient way to solve the problem...
The other way will be the more traditional one:
LIBRARY ieee;
     signled           : out std_logic;
     segmento          : out std_logic_vector(6 downto 0); -- Bit 6..0: segment F..A
     operation         : in std_logic                      -- 0 = add, 1 = subtract
signal sresult : signed (3 downto 0);
signal uresult : unsigned (3 downto 0);
begin
   -- calculate the result (range -8 to +7)
   sresult <= signed(chaves_a) + signed(chaves_b) when operation='0' else
              signed(chaves_a) + signed(chaves_b);
   -- display the sign
   signled <= sresult(3);
   -- make the remaining number unsigned (range 0 to +8) --> less definitions for display
   uresult <= unsigned(sresult) when sresult>0 else
              unsigned(-sresult);
   -- display the unsigned number
   with uresult select segmento <=
30
      "0111111" when "0000",    -- 0
31
      "0000110" when "0001",    -- 1
32
      "1011011" when "0010",
33
      "1001111" when "0011",
34
      "1100110" when "0100",
35
      "1101101" when "0101",
36
      "1111101" when "0110",
37
      "0000111" when "0111",
38
      "1111111" when others;    -- 8
39
40
end Behavioral;
And voila: according to the waveform in the testbench its running very
fine... ;-)
von Andreas S. (Company: Schweigstill IT) (schweigstill)
Lothar M. wrote:
> fine... ;-)
Are you sure? ;-)
Andreas S. wrote:
> Are you sure? ;-)
Oooops, you are right.
With a '-' its working better. Let me say it was a little test...  ;-)
