Forum: FPGA, VHDL & Verilog Real-time data acquisition
von Assuero S. (Company: Student) (assuerosavio)
What is the best to do data acquisition in real time, is there a
specific library? Input an analog signal, encode and store its reading,
ensuring a constant time in the range of the samples. Thanks for the
help.
von Klakx (Guest)
maybe you need an oscilloscope? you must be more precise, you wont find
a simple library like in software
My work is similar to the oscilloscope, how do I scan the A / D signal
and store it in fpga's memory? it's possible?
von -gb- (Guest)
Which AD Converter do you use? Which type of interface? Parallel data
and clock?
It is quite simple, just store the data at a clock edge. Store them in
block-RAM, in an FIFO, ...
Assuero S. wrote:
> it's possible?
Yes, indeed.
First you must implement an interface to the DAC,  then you must
implement some kind of mass storage to memorize that values.
Assuero S. wrote:
>  is there a specific library?
Look for "soft cores" for that specific tasks. Expect prices about
10-50k each.
If that is too much, then do it on your own. If you encounter problems
then ask specific questions and supply necessary information (eg
language,  target device, toolchain... )
