Forum: µC & Digital Electronics Generating a 1 Pulse Per Second using MSP430
von Omer D. (Company: OrnetPower) (omerdf)
Hello ,
I'm new in Micro Controller field and i have been doing some readings
(along with some relevant DataSheets) , although i still didn't
understand few things .
I'm using MSP430F5131 and attached an external crystal of 12.8MHz to
pins PJ.4 and PJ.5 .
I would like to generate a 1 pulse per second using this external clock
while the output of the 1pps should be P2.4 , im also using Timer D
(TD0.0) .
Could you help me writing the code (I'm using Code Composer Studio)
about how to generate that 1 pps using the external crystal and Timer D
(TD0.0) and how to define the timer d and external crystal.
thanks in advance.
: Moved by Moderator
von l0wside (Guest)
Start with studying and understanding the Device Clock Tree (which is
not trivial in MSP430). Then, get TI´s samples and try to generate at
least some output on P2.4. Once you have some output, you can start
modifying its frequency. Do you have an oscilloscope or a logic
analyzer?
yes i do have one .
I tried to figure out the code syntax.
they use #pragma function in order to use the clock register vector,
although i havn't seen any information about that.
where can i find information about these kind of syntax? and where can i
find a CCS example code that could help me doing that?
could you recommend on a datasheet that can help me figure out the basic
of the msp430 along with code syntax?
thanks.
von Clemens L. (c_l)
If you don't even know the basic C syntax, I'd recommend looking at some
tutorials:
http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_Tutorials
thank you ill take a look.
