Forum: FPGA, VHDL & Verilog VHDL Code for 'String Parsing' circuit
von Omar (Guest)
I am designing a VHDL combinational block that takes in a list of 8
ASCII characters as input and replaces the non-numeral characters with a
dash '-', then rearranges the list to have the numerals on one side and
'-'s on the other.
Example input and output:
Input: d126r24!                      Output: ---12246
Here's my source code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity module1 is
  port (list1: IN string (1 to 8);
        list2: OUT string (1 to 8));
end entity;
architecture behavior of module1 is
signal temp: string (1 to 8);
begin
process (list1)
variable a: integer:= 1;
variable b: integer:= 8;
variable c: string (1 to 8);
begin
for i in 1 to 8 loop
  if ((list1(i) = '0') or (list1(i) = '1') or (list1(i) = '2') or (list1(i) = '3') or (list1(i) = '4') or (list1(i) = '5') or (list1(i) = '6') or (list1(i) = '7') or (list1(i) = '8') or (list1(i) = '9')) then
    c(a):= list1(i);
    if (a < 8) then
      a := a + 1;
    end if;
  else
    c(b) <= '-';
    if (b > 1) then
30
      b := b - 1;
31
    end if;
32
  end if;
33
end loop;
34
35
temp <= c;
36
end process;
37
list2 <= temp;
38
end behavior;
testbench:
library ieee;
entity tb_module1 is
end entity;
architecture behavior of tb_module1 is
component module1
end component;
signal list1, list2: string (1 to 8);
begin
DUT: module1 port map (list1 => list1, list2 => list2);
process
begin
wait for 0 ns;
list1 <= "12345678";
wait for 10 ns;
list1 <= "001122nn";
wait for 10 ns;
end process;
end behavior;
They compile fine but simulation gives me this error in the image
attached. I cannot understand why this error is happening! It keeps
saying that my index is out of range...
von Klakx (Guest)
Maybe it is only this: c(b) <= '-'; should be c(b):='-';
von Omar (Guest)
That still did not fix the problem. I modified the code to :
library ieee;
entity module1 is
end entity;
begin
process (list1)
begin
    c(a):= list1(i);
    a := a + 1;
  else
    c(b) := '-';
    b := b - 1;
  end if;
end loop;
30
31
temp <= c;
32
end process;
33
list2 <= temp;
34
end behavior;
I still get an index out of range error as my attached capture shows.
Please help me understand...
: Edited by Moderator
von Klakx (Guest)
in the 2nd use of the process at 10ns ur variables a,b are not reseted.
Initialize them at the beginning
von Omar (Guest)
I thougjt initializing them at the beginning of the process does that?
Doesn't that happen everytime the process is triggered? Or is it only
the block after 'begin' that gets re executed?
Thanks O will try that.
