Forum: µC & Digital Electronics Emulating a Floppy disk controller?
von Josef (Guest)
'morning,
I've found numerous articles discussing how to emulate a floppy disk
DRIVE, here and elsewehere and there even seem to exist commerial
solutions.
Yesterday I revived an old SB180FX (HD64180 CPU with a CP/M compatible
OS) and had been contemplating beforehand what to do if the floppy
drives or the disks failed. I was wondering if it were possible to
replace the floppy controller (FDC9266) by a microcontroller that
emulated the FDC (register read/write, DMA) and stored the data blocks
on an SD card or such (anyone know if SD cards with 1.44MB capacity
exist? ;-) ).
I would read/write the raw data on my PC, so the controller would just
map the floppy's blocks 1:1 to the SD card or even map all four drives
to separate sections on the SD card.
The bus speed to the processor (running a ~12MHz) would need some
attention, maybe adding hardware support in the form of a flipflop which
generates WAIT cycles (within reasonable limits) by being set
automatically by any access and which is then reset by the
microcontroller. This only affects the reading/writing of commands and
status, after that the microcontroller would work internally
transferring data via (emulated) DMA.
I'd prefer an ATmega of sorts.
Question: has anyone done this before?
Josef
von KarlKurtz (Guest)
von beric (Guest)
von Josef M. (Company: Privat) (jmoellers)
Using a floppy drive emulator is all nice and well if you have a
floppy controller to attach your drive emulator to. Unfortunately the
FDC9266 I had has turned out not to bee 12V-resistant :-(
I have ordered a few 9268s from Mr. Chinaman but the order is still
pending.
In the event of non-delivery, I will have to dig up something that is
able to replace the 9266. So, unless someone has a 9266 (or 9268) that
(s)he wants to part from, I'll try to emulate the controller.
Josef
PS Getting the data off the original disk(s) is another problem: 1024
Bps, 5spt ... Maybe I can convince the Linux floppy.c driver to read the
disk(s).
> disk(s).
This drive might be a solution: "TEAC FD-235HS 1111 SCSI Drive":
According to the datasheet it can, indeed, read 1024 Bps.
