Forum: FPGA, VHDL & Verilog Linking Modules Instantiations
Author: Benjamin L. (Guest)
In my code I have two instantiations of different modules:
module1 myModule1 (in1, out1);
module2 myModule2 (out1, out2);
As you can see, my main goal is to make the input on my second module be
dependent on the result of the output of my first module. However, to my
understanding, out1 doesn't have a value at the beginning since
everything happens at the same time and out1 hasn't been calculated from
the first module. How am I supposed to go about this in code?
Author: P. K. (pek)
If you give all storage elements (e.g. registers, memories) an initial
value and you have all inputs well defined, everything is OK.
If not (i.e. you'll get unknown or undefined signals in your simulation)
track the signals down to where they origin from and give initial
values.
Even if you don't give initial values for the storage elements, they
should eventually end up in defined states in a good design (inputs are
mandatory to be well-defined, of course).
: Edited by User
Of course it has.
It has a undefined or (if you have been clever) any initialized value...
> out1 hasn't been calculated from the first module.
What kind of "module" ist that? Is it combinatorial or is it registered?
  • [vhdl]VHDL code[/vhdl]
