Forum: FPGA, VHDL & Verilog Transistors in Verilog
Author: Benjamin L. (Guest)
I am currently trying to use an nmos and pmos in my verilog code.
However, when I try to synthesize my code I get an error that says:
"cannot synthesize MOS switch gate primitive". What is the solution to
this error?
What platform? What target? What toolchain?
For sure you cannot synthesize a simple transistor gate on a FPGA,
because all of the transistors in there are used by the manufacturer...
Author: Falk (Guest)
@Benjamin L. (Guest)
>this error?
Just forget about it and learn what verilog is really used for.
So your saying it is impossible to use pmos and nmos declarations when
dealing with FPGAs? If so, then why do they even include those type
declarations in verilog? Is there any other possible workaround, per
say, creating the pmos from scratch?
Author: Strubi (Guest)
1) If you really want to synthesize: Read about your FPGA's primitives.
They're called primitives because that's the most atomic thing you have
access to on your FPGA.
2) If you want to simulate: You could certainly do that, but typically
people use Spice or Qucs models for MOS transistor simulation
> dealing with FPGAs?
You got it.
> If so, then why do they even include those type declarations in verilog?
Who are "they"?
The (until now unknwon) FPGA manufacturer? Or who else?
To keep thing short: out of the 100% that is possible to do with Verilog
about 5% can be synthesized on a FPGA. With that transistor You try to
do something out of those 95% impossible things...
The relevant document for Verilog on a FPGA is the synthesizers manual
from the FPGA manufacturer. In that manual you find synthesizable
templates and code snippets.
> Is there any other possible workaround, per say, creating the pmos from
> scratch?
As already said: NOT ON A FPGA. If you want "your" own transistor, then
you must do "your" own ASIC. Alternatively you can pick one of the parts
out of an ASIC manufacturers library...
BTW: did you read my 3 questions?
: Edited by Moderator
I meant simulate and NOT synthesize. So knowing that, is it possible to
simulate such transistors without getting that error?
@Lothar Miller
I meant the designers of verilog/quartus. Why would they include the
functionality of having pmos(...) if you can't even use it
those are completely different people with totally different aims.
You may find a Verilog description of a transistor, but for sure you
will not find that transistor in any relationship to Quartus. That's
because you can use Verilog (in however way) to design that transistor,
but Quartus never ever will synthesize it on a Altera/Intel FPGA.
To keep things short:
Verilog is not Quartus. And Quartus is not Verilog. They overlap
just for 5%.
Quartus not even is a simulator. It's ModelSim that's used for that job.
So at first you must get a clear picture about your toolchain. Otherwise
it may be the same like taking a wrecking bar and try to hammer a screw
into the wall: wrong tool and wrong strategy for that job..
  • [vhdl]VHDL code[/vhdl]
