Forum: FPGA, VHDL & Verilog Automated Validation of Combinational Circuit
Author: edadev55 (Guest)
  • add.v (528 Bytes, 46 downloads)
I am fairly new to FPGA/Hardware design, so pardon if the question isn't
appropriate for this forum. This question is pertaining to approaches
available for automating validation of testing any combinational circuit
in a synthesized implementation. I will try to explain it with an
example
Say i have verilog module called ADD designed to add two numbers. Code
for same is attached. Now as i understand, there are two methods with
which i could validate the verilog module designed. They are using
    A. Simulation
    B. Synthesis.
For simulation purpose, i have used icarus verilog and created a test
module that would instantiate the adder module and feed it various
values and check the result with values computed. This is just provided
for an illustration. Obviously for different circuits the test bench and
testing method on simulation would vary.
Now for synthesized implementation, i am planning to use Xilinx FPGA. As
i understand, we cannot use timing controls like #1 in the synthesized
implementation. One approach, i could think of is creating a Look up
table contain all test cases input and expected output and have it as
part of the design. Run a counter and use the LSB bits of the counter to
decide the test input for a given clock and check the output, in the
event
of difference, write into a flip flop whose output would be used to
turn-off a LED. Thus i could check whether the design has passed all the
test conditions provided based on LED output status.
I am wondering if there are better approaches for performing validation
of a synthesized implementation. For instance
A. Is there a way by which say, test inputs are available in a PC and
can be streamed and generated output can be fed back to a file in PC.
B. Is there a way to mimic timing sequence control available in
simulation and get tests done in synthesized implementation apart from
using counters.
As i am a newbie to this, i am wondering how is this problem tackled in
general. Any links to reference material that i could read through would
be highly appreciated.
  • [vhdl]VHDL code[/vhdl]
